So I was taking my old alt off and I snapped one of the bolts that hold it on. Its a 98 Ford Expedition. I got 2 brand new alts and I can't even install these things yet!!! Damn. Do anyone know of any way to get it out? I know I can use a drill but that's a very small area. Maybe a 90% drill will do the trick. Any suggestions?
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
does the bolt go into the engine block or stuck in a bracket?
1998 jeep grand cherokee
future teardown and rebuild:
2-15.4 orion hcca's
sub amp undecided
2 sets of components
1-concept amp (mids/highs)
undecided h.o. alt
2-yellow tops
pictures would help
R.I.P!
(Nov-29-2009)
92 explorer
current build
drill bits, heat, easyouts, all depends on where the bolt is or the situation is. pics would help for sure
if its stuck in the block u r S O L that is why u use a wrench not a hammer lol
did he say he used a hammer? :rolleyes:
NoFearX18 said:
trainman0978 said:
for me getting bolts out
is to spray PB blaster on it
let it set for 5 mins
heat it up with a propane torch
1998 Nissan 200sx
NOW:
Dex-p98r head
Planet Audio 300.4 mids and highs
Planet Audio/Pioneer tweeters/crossovers
Skar SK1500.1
3 SKAR Vvx15 dual 4 wired at .63
Well its dark so pics won't happen right now. I don't know where he got HAMMER from. LOL. Basically the head of the bolt snapped off. I can actually reach behind the alt and feel almost 1/2 inch of the threads sticking out so I should be able to make it happen. I might be able to use some PB blaster and take some needle nose pliers and turn it from the rear.
lol needle nose prob wont work but yeah spray that bish down, hell let it sit over night even and try to gety something grabbed onto it. if not try getting it heated up, torch stlye and try again. it will come out if its not one with the truck lol
