I am planning on building a slot vented box this weekend for my two Audioque SDC2.5 15 inch subwoofers and i came up with a design but i want to know if someone can estimate what my tuning will be and what net volume my subs will see. My box will 48 inches Wide, 18 inches tall, and 26 inches deep. The Port will be 8.5 inches wide and 16.5 inches tall. Also total port length will be 26 inches. Wood will be .75 inch thick and sub and port will face to the rear of a truck. I am shooting for a 35 hz Tune with 9 feet of net volume for both subs together. Please help!!
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
as far as i can tell using Exposport's box calculator found on this site, your box will net around 8.5 cubic feet tuned to 32 hz with all of the dimensions you provided. I changed a few numbers for you. If you make the port length 15 inches instead of 26 you will be tuned to 35 hz and net 9.36 cubic feet. just thought i would try to help. I also guessed at your subs displacement since i could not find it so i ballparked using my subs as an idea. I put in .25 cubic feet for both of them.
i'm going to name it Fred
R.I.P!
(Nov-29-2009)
92 explorer
current build
can u make the box any bigger?
what amp
what kind of bracing will u be using
stick to 16sqin of port per cuft
ur gonna want to have more volume and higher tuning, 34-38hz is great for those subs
ill help more when i get a few more answers
what amp
Thanks a lot for helping me out people and i think i might be confused with total port length and physical port length. The actual wood for the port will be 16 inches deep but the 26 for port length is me adding the L1, L2, and end correction which is 4.25 since my port width is 8.5, i hope i make sense. Also yes i want the box to be 9 cubic feet internally so each sub can see 4.5 feet, and i want the tuning to be 35 or 36 but no more than that. I will also stick with the 16 sq inch per cubic feet rule which i am following. My amp is the Audioque 1200d.
Also just to clarify my box instead of it being 48 inches wide i am making it 47 inches wide i just mistakenly put 48 inches.
  • Who's Online   0 Members, 0 Anonymous, 946 Guests (See full list)
