Hifonics 1610D Problem
xpfx
This amp is about a week old. I've checked and re-checked all the connections and they seem to be all good.
The does not get warm, or smelly, just randomly it will turn off and come back on when it wants to.
What could be causing this? The only thing that I can think which I didn't think would matter is my Mids/High Amp remote wire I spliced into for the Hifonics amp.
Any input would be greatly appreciated. I can still get a RMA number and send it back, just don't know if its something i have hooked up wrong or the amp itself.
Thanks in advance,
Cody
edit:
How its wired:
Power wire running back from battery into a distribution block, 4 guage into both amps
RCAs ran normally
Remote ran back from the radio fuse in the fuse box and spliced for two amps
Ground is to a bolt under the back seat, bare metal that was sanded down.
2 Alpine Type R 1242Ds wired to 1ohm.
1999 Ford Expedition XLT
Alpine iDA-x100
Alpine Type S 5x7's x4
Kicker OSKS13 1/2" Tweets
Kicker 08ZX350.4
Alpine 1242D x2
Hifonics BXi 1610D
1/0 Knu
1/0 Big 3
Yellow Top Up Front
Daily Driver
Thanks in advance,
Cody
edit:
How its wired:
RCAs ran normally
try taking the remote line thats spliced and only run it to the 1610....if it stays on, then Id suggest wiring in a simple relay just to boost the remote wire signal....
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
x2 on checking this but also did u check the fuses?? Just take your time going step by step, as if you were initially installing the amp again.
Pioneer AVIC-N2
The fuses looked like they were getting corroded and the amp is less than a week old, what causes that? I'll definitely do the remote wire.
Alpine iDA-x100
Kicker 08ZX350.4
Alpine 1242D x2
Hifonics BXi 1610D
1/0 Knu
1/0 Big 3
Yellow Top Up Front
Daily Driver
Take the advice of the few, trust me they know what they're talking about... I would also recommend redoing the remote and checking over all of the grounds.
definitely what marlo said too....but where did you put the fuses man? sounds like water may be gettin to them...if that line is corroded and not making a good connection, that could be your problem too
The fuses on the amp itself are corroded.
Alpine iDA-x100
Kicker 08ZX350.4
Alpine 1242D x2
Hifonics BXi 1610D
1/0 Knu
1/0 Big 3
Yellow Top Up Front
Daily Driver
  • Who's Online   0 Members, 0 Anonymous, 773 Guests (See full list)
