kingcabon20s Posted January 17, 2010 Report Share Posted January 17, 2010 lost the instructions for my alt i had the 220 amp alt for the 96 nissan 2.4 4cyl could you please send me a set to my email or post em?? Quote My seller feedback. Link to comment Share on other sites More sharing options...
kingcabon20s Posted January 17, 2010 Author Report Share Posted January 17, 2010 Got the altenator in i have the belt very tight compared to my other 2 is this a problem do i need to loosen it up some? Quote My seller feedback. Link to comment Share on other sites More sharing options...
MECHMAN Posted January 18, 2010 Report Share Posted January 18, 2010 Got the altenator in i have the belt very tight compared to my other 2 is this a problem do i need to loosen it up some? Because of the pulley used on that truck, you are going to need the belt very tight to prevent belt slip, it is supposed to be that way. regards Matthew Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
kingcabon20s Posted January 18, 2010 Author Report Share Posted January 18, 2010 its vverryy tttiiighhhtttt i didnt get a dyno sheet with my altenator but was curious what should resting voltage be?? its sitting at 14.5-14.6 resting i turned on my single compressor last nite voltage didnt even drop time to slap the other compressor in an get to installing my audio. Quote My seller feedback. Link to comment Share on other sites More sharing options...
MECHMAN Posted January 20, 2010 Report Share Posted January 20, 2010 its vverryy tttiiighhhtttt i didnt get a dyno sheet with my altenator but was curious what should resting voltage be?? its sitting at 14.5-14.6 resting i turned on my single compressor last nite voltage didnt even drop time to slap the other compressor in an get to installing my audio. 14.3-14.8 volts is typical at idle, depending on tempurature. Glad to hear it is living up to your expectations! Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
