DC Sound Lab
he could have it wrong .. if wiring in series he could have one coil wired wrong . thats what I am saying instead of hot to hot and ground to ground he could have it hot to ground ground to hot ... get it ?
in a hurry and plug & play and accidentley wires backwards on 2nd coil when jumping ....
Edited by Tooshort064
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
then the sub wouldent move ( ive done it) it wouldnet have much output if i understand you correct
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
i think i found the problem the nuts were loose that hold the wires on the back of the sub box. i thightend them up and retried for ten minutes and they stayed cold the whole time. my subs do get warm and i dont smell coil but i may have smelled a little tonight and man do i have a burnt finger lol.
mobile chornobyl
im using knu's 8ga power wire for my speaker wire... and i dont think its getting warm... then again.. most of the time.. my gain is way down (mids cant keep up)...
i would turn the gain down...
edit:
if its sparking.. somthing is shorting... check that first...
edit again...
nvm... lol
pics would be helpful
Edited by spl4life
My first truck... My first Real build...
*Update 8/9/10 DC Power 270xp Alt is In!!!*
1997 Toyota T-100 DC Level 5 18" in a T-line
Everybody wants their system to be....
1. Cheap
2. Reliable
3. Loud
...you can only pick two.
micahmye hertz pack
X2 that. Is what I was thinking you have to torque them down or they will build up. A lot of heat I always go over them with goop after all connections are good and tight to keep them from backing off.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
i was going to do that a couple of months ago but forgot i just nuted up when i seen them burning because i had just hooked up a new amp. i will be geting them gooped up now.
mobile chornobyl
edit:
edit again...
nvm... lol
i deserved that
mobile chornobyl
  • Who's Online   0 Members, 0 Anonymous, 6388 Guests (See full list)
