Sorry for all the posts lately, i've used the search button and checked older posts and i cannot find the answer i need. Alright so i had a stock alt 105 amp with 8 to 10 gauge wire and with my setup in dipped into the 11's. Well im starting the big 3 and i have a 220 high output alternator on the way 110 idle 220 1200 rpm, and i wanted to ask is a second battery needed, will it be alright just to run the new alt, and good batt up front
Edited by Toady
With the big 3,H/O alt, and a big good battery up front you will be fine. I would put an extra battery in the back just to be safe. Nothing big, just a small extra battery like a HC600 or something along the same lines.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
that wire would let you safely pull maybe 50 amps at best.
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
What amp(s) are you running??
Pioneer AVIC-N2
the more power you have for your amps the better it is,so for every battery that you do add its a gain!];
also if its the equipment in your sig you should be fine with
High out put alt
Big 3
Nice battery upfront
you should be good
also maybe 1/0 gauge?
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
Sorry to confuse everyone i left out a big detail, I have 20 feet of Kicker 1/0 Hyperflex cable that im using for my big three upgrade, that ima run to the alt and grounds and everything
If you can afford it get you a nice deka batt in the back. Do not remove your stock wire just add the 1/0 for the big three. the big batt in back will be nice when you upgrade which you will when you hear the BIG BASS your setup will put out now with your new alt and all. :D
  • Who's Online   0 Members, 0 Anonymous, 2803 Guests (See full list)
