kl0wn Posted January 19, 2010 Report Share Posted January 19, 2010 Okay well my buddy has had the same ipod for a really long time (one of the first generation nanos IIRC). He just decided to go out and buy a 5th generation nano so he could carry more music around. He just plugs it in and throws it into his glove box. With his new iPod, when he plugs it in, the deck will still play music from it and everything, but will not charge it. So I did a little bit of searching and came up with this. Will this adaptor make it so it charges his iPod when plugged up into the H/U? 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz Link to comment Share on other sites More sharing options...
thehoe92 Posted January 19, 2010 Report Share Posted January 19, 2010 Select a song from your iPod or iPhone and begin enjoying your music while charging typically if its connected via dock connector its being charged Wouldnt be thehoe92 without teh purple Link to comment Share on other sites More sharing options...
kl0wn Posted January 20, 2010 Author Report Share Posted January 20, 2010 typically if its connected via dock connector its being charged Well, it's being connected to the dock, but it says the iPod is not recognized. It is still playing music from the iPod, but it says on the iPod screen that it is not charging it. 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz Link to comment Share on other sites More sharing options...
treossi Posted January 20, 2010 Report Share Posted January 20, 2010 happened to mine a few times 99 percent sure this is the problem http://support.apple.com/kb/HT1320 1 Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) 2 Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details Link to comment Share on other sites More sharing options...
k3n12ock Posted January 20, 2010 Report Share Posted January 20, 2010 I'm not sure if that will work but I'll tell you this. I had an old 30gig iPod video and my Pioneer was able to charge it. When that broke, I got an iTouch. My Pioneer would not let me charge the iTouch. It could be something with the newer ipods not being able to charge unless you buy a certain adapter. Like I said, I don't know if that one will work. 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2 Link to comment Share on other sites More sharing options...
Boon Posted January 20, 2010 Report Share Posted January 20, 2010 A lot of older headunits charge the ipod over Firewire charging. New iPods don't support this, they charge over USB. That scosche thing shouuuuld solve it for you. 10.x volts fo' life! Link to comment Share on other sites More sharing options...
total mayhem Posted January 20, 2010 Report Share Posted January 20, 2010 Okay well my buddy has had the same ipod for a really long time (one of the first generation nanos IIRC). He just decided to go out and buy a 5th generation nano so he could carry more music around. He just plugs it in and throws it into his glove box. With his new iPod, when he plugs it in, the deck will still play music from it and everything, but will not charge it. So I did a little bit of searching and came up with this. Will this adaptor make it so it charges his iPod when plugged up into the H/U? That is the correct unit that you need. All of the new ipods charge at 5 volts now verses 12 volts on previous models. I have the same unit in my truck attached to my 3rd gen itouch. LOUDEST PHUKN BURB N LA COUNTY!!!! Team SoCal SPL Team Sundown Link to comment Share on other sites More sharing options...
Ray Posted January 20, 2010 Report Share Posted January 20, 2010 That is the correct unit that you need. All of the new ipods charge at 5 volts now verses 12 volts on previous models. I have the same unit in my truck attached to my 3rd gen itouch. you are correct. older apple stuff is 12v newer ipod IE: 5th gen ipods and 3g iphones charge @ 5v the cable is a voltage stepdown. Sucks it has to be done that way, but it works. All 2010 decks will now charge both 5v and 12v 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
