Hmmm that much power id keep it at taht 7.5 or something cuase 4.5 cubs each would seem a little too big and then youd have mechanical issues i would think with that much power
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
You can run either setup and have a good sound with no detriment to the subs. 8cu is great for two 15s. You could even go 10cu with the right port/power.
To answer the literal question though, "too big" will just mean a loss of cone loading, power handling, and resonant freq inside the box. The sub will act as if it's in an infinite baffle setup at a certain point which is something you don't want. It would have too be blatantly too big for that though.
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
this is the enclosure type!
to give you guys an idea!
do you think 1 cubic foot bigger will make alot of diffrence!
im kinda of a newb!
Edited by 03navi
Vehicle: 2003 Lincoln Navigator
Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust
Amplifiers:Kicker Kx2500.1, MA Audio M700XE
Batteries: 1 Kinetic Hc2400 Battery
Electrical: STOCK Charging System! Tsunami 40farad Capacitor,
Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz)
Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter
Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter
Subwoofers: 2) 15 Power Acoustik Mofo
Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable
Video: http://www.youtube.com/2treo15
also the subs in my other truck require a 6 cubic foot box with aero port 3x9(the companies dimensions), But i gave them a 8 cubit foot box with aero ports 4x10 and they sound good!even though the box is 2 cubic feet bigger!
help?
you forget that there is no bracing or nothing in that box once you add bracing and add the subs the box will shrink internally
R.I.P!
(Nov-29-2009)
92 explorer
current build
what do ytou guys thing i can add in bracing to get the box to oraund 7.5-8.0 cubic feet? anyone?
