2x4s you can brace lilke this
R.I.P!
(Nov-29-2009)
92 explorer
current build
for 15's, depending on power, i use 3-5 cubes per 15. i had my old 15's in about 4 cubes per sub with ~12 sq inches of port per foot. and i personally wouldnt tune to 29 hz, i find it pointless. i stay in the mid 30's. you're only going about .5 cubes bigger per sub after displacement (give or take .5 for displacement), so i think you'll be fine
okay thank you very much!!will this make the enclosure internally smaller?
Vehicle: 2003 Lincoln Navigator
Exterior:Custome Air bags, Chrome Grill, 8000K Hid Low & Fogs, 24in rims,Corsa dB Performance Exhaust
Amplifiers:Kicker Kx2500.1, MA Audio M700XE
Batteries: 1 Kinetic Hc2400 Battery
Electrical: STOCK Charging System! Tsunami 40farad Capacitor,
Enclosure: 8 ft³ tuned to 45Hz Interchangeable Ports(34Hz)
Headunit: STOCK! (DVD,CD,Navigation), AudioControl LC6i, AudioControl Epicenter
Mids/Highs: (4)Sets Of Focal Access Component 690 CA1, 2) Sets Of Infinity Reference Tweeter
Subwoofers: 2) 15 Power Acoustik Mofo
Wire: Multiple Runs Of 1/0 Gauge Streetwire Cable
Video: http://www.youtube.com/2treo15
im goin to run a kicker kx 2500.1 on each subs!
ill be running about 4.9K
If you make the box oversize. Then you don't need as much power. If you make box too small. Over power. As far as bracing. Make it 2 layers thick all way around and interlock the 2nd layer over the first. I always glass the outside of my boxes. Extra strength.
2004 Mustang
3 18s
6 crossfire bmf 1700s strapped @ .5
161.2 db Daily driver
159.4 @ 45 hz
158.7 @ 35 hz
154.4 @ 25 hz
Team Hz Addiction
http://www.youtube.com/Drek75633
what do you mean by interlock the 1st and the 2nd layer?
Making a box too big isnt bad, just cut up some MDF to use as "filler" and add it internally to the box to take up the extra space. On a side note, decreasing internal volume without modifying the port will decrease tuning frequency. Can always mod the port later.
Yes bracing counts as filler.
Edited by STEvil
Hammerdown... 1%
modding the port would be hard for me to do!
Say you made the 1st layer of the box where the baffle for the subs layed on top of the 4 corners. When you go around to putting a 2nd layer of mdf on. Make the 2nd .75 inches shorter on each side and raise the corners of the box. So the pattern overlays. Making it stronger.
2004 Mustang
3 18s
159.4 @ 45 hz
158.7 @ 35 hz
154.4 @ 25 hz
Team Hz Addiction
anyone?
