I know this is probably not a well thought out question as i did no research at all but I'm going to ask anyway. I know Fi does not give a sealed enclosure figure for the BTL or BL, what would happen if you put them in a sealed box? I was just woundering. Thanks in advance...
Build in progress:
Kenwood DNX890HD
Rockford Fosgate White wolf RCA's
2 Rockford Fosgate T400.4 on RF fanatic q components (6.5 in the kick, 6.5 in the front doors, 5.25 in rear doors)
2 Rockford Fosgate T2500's on sub
1 Fi car audio Team 15 D1
XS Power D3400 and three D975's in the rear
Mechman Elite 370
Stinger power connections and cable
It's probly going to sound like ass and the box will get blown up. If you want a sealed box do not put a BTL in it. It will end up being bad news
-Car: 2006 Ford expedition King Ranch
-Subs: 2 FI BTLs 18 fully loaded
-amps: 2 sundown SAZ 3000D
-Alternator: DC Power 260 amps
-Batterys: 2 optima yellowtops
-A whole shit load of 0 guage knu hyper flex and raptor cable
-Rockford Fosegate 3sixty
There is a general rule of thumb when determining if a driver will work in a sealed / ported enclosure, or both!
The formula is the Fs of the driver divided by the Qes of the driver. So Fs / Qes will either give you a number less then 50, between 50 and 100, or over 100.
If the number is below 50, the driver will work best in a sealed enclosure.
If the number is between 50 and 100, the driver will work both in a sealed or ported enclosure
If the number is above 100, the driver will work best in a ported enclosure
So, lets do some basic math.
12" BTL D1
Fs= 39.3hz
Qes= .21
39.3 / .21 = 187.14
15" BTL D1
Fs= 35.6hz
Qes= .24
35.6 / .24 = 148.33
18" BTL D1
Fs= 31.9hz
Qes= .26
31.9 / .26 = 122.69
None of the drivers fall between that 50-100 range, leaving the BTL best suited for a ported enclosure. However I am curious to see how a BTL sealed in various sized enclosures would plot in winISD, maybe I will post again later with results.
Too Much Stuff to list .
  • Who's Online   0 Members, 0 Anonymous, 876 Guests (See full list)
