I am Working on a Project called B.A.B (Big Ass Box) it is a 30x 36x 14 t-line or Horn enclosure, in the trunk of a Ford Focus Sedan. It will hold 2 sets of Isobaric 10 Inch Sony Xplod Subwoofers.
I made several Designs before I rested on my Final Setup.
This is for a Single Sub Design.
This Was for a Isobaric Setup. I added more Bracing to reduce rattles
This is the Design I settled on.It will have the Non used Squares between the walls
Filled with expanding foam or PolyFill.
I will keep the thread updated with Pictures as I make Progress. I have it all marked out on 1 1/2 sheets of 3/4" Mdf Board.
I am open to any Comments suggestions and Criticisms . I may use some PVC pieces in the corners to allow the wave to bend.
hopeful noob
you could do a single throat t-line with 2 sub coutouts at the beginning of the throat and calculate the mouth to the desired sd :01nocomment8so:
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
Now I know what you mean .You mean basically the first or second design with a second cutout
yeah, just like that or this.
Depending on the measurement method used weather it center line or other ,It measure a length of 82-88" length . Ideal distance is 84" for these Drivers.
I have learned from researching that
From fs derive ¼ wavelength, chop 5% off that figure – this is your line length.
hopeful noob
  • Who's Online   0 Members, 0 Anonymous, 652 Guests (See full list)
