i got this amp and it was working fine for about a month..
all of a sudden as soon as i connect any sub to the amp the sub will sound as if its plugged into a wall socket and it will blow it within seconds..
i mean any sub.. the amp is 600 watts rms.. it blew a 15'' mtx 9500 also a 12'' jl w7 ... the mtx sub was mine and the lw7 sub was my friends.. it was his brite idea to try it on my amp.. he said no amp can blow that sub.. stupid idiot..lol..
but yeah i stuck my multimeter in the speaker terminals of the amp when powered on and they read 58.3 volts.. is that fucking crazy or what..?
is this normal.. and there was nothing hooked up to the rca's either..
what could be wrong with the amp..? thanks
4 15'' kicker L7 subs ( only 2 being used right now )
1 kicker zx2500.1 ( another soon 2 come )
box is 9.5 cubic feet slot portd thur the back seat
1 kicker zx650.4 amp powering 4 10'' ev dl10x mids ( rear deck )
1 kicker zx350.4 power 4 8'' beyma 8mi100 mid/highs ( 1 on each door )
2 runs of zero gauge wire ( about 60 feet total. )
big 3 done in zero gauge kicker wire
3 runs of 4 gauge for voice amps and eq' and crossover
2 kinetik hc1800 batteries in the trunk and 1 optima yellow top under the hood
260 amp irragi high output alternator ( soon to be 2 alt's )
alpine cda 9856 ipod headunit
kicker kx3 3 way crossover & a old school alpine 3342 digital 11 band sound field processor eq.
( search for ( 88bonnsse ) on youtube.com to see my videos..
are ur gains down ?
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
check if ground is in your + input/ + in ground
R.I.P!
(Nov-29-2009)
92 explorer
current build
I had almost the exact same problem when I did my tunnel build. Fortunately, the load was spread across too many subs to blow them, but it was a fucking LOUD burp that scared the shit out of me.
IIRC the problem for me was a speaker wire popped out of the amp and fell on one of my battery's terminals. I don't remember which terminal, but that was my issue.
Need an install? Hit me up.
[email protected]
Got car audio questions? Check here first!
Everything you need to know. =]
http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
or also check your ground and power and rem wire if its got any cuts gashes anywhere or open the amp and see if anything looks out of place
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
my wires are all fine.. power, ground, remote and speakers..
i even bench tested the amp with a kinetik battery and a 10'' pyramid sub i had and the second i put the speakers from the sub to the amp even with no signal plugeed into the rca's the sub was flexing like no tomorrow then blew out and smoked within 10 seconds..
and gain is less then 1/4 the way up..
i believe its the amp but i looked inside and nothing seems burnt or popped..
also is the 58.3 volts reading from the speaker terminals on the amp that im getting any good..? its sounds like way too much voltage to me..
what amp is it
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Sounds like the amp needs to go in the trash. 58 volts is bad news. I can only imagine the current draw depending on the impedence of the sub.
Warm Regards,
Dyno Brian
1997 Ford Probe
|Sony Head Unit|Alpine V12 AccuClass-D MRD M1000 Amplifier|4 RE AUDIO SRX12D4 12's|Mids and Highs coming soon!|
|1998 Mustang GT Twin Turbo|1986 Mustang GT Single Turbo|1996 Mustang Mystic Cobra N20|1995 Mustang Cobra 5,000 miles|
2002 ZO6
i have the exact same problem but its with my 4 channel amp! as soon as i put the signal in, it burnt my comps, the amp is new and i have no idea?
REFF'S
My link
EBAY
  • Who's Online   0 Members, 0 Anonymous, 386 Guests (See full list)
