Fi BTL help
Ok guys I have an 18 inch Fi BTL Dual 1 running off of an orion hcca d5000. When I play it at full blast for maybe 1 minute, the dustcap gets hot and it starts to smell a bit. At full blast my voltage drops to about 11.5 volts. i just set the gain with a multimeter and it still gets hot and smells. Also, the amp does not even get warm when it happens. any ideas?
thanks in advance.
thanks in advance.
is it the 5000 rms at 1 ohm one or 2500 at 1 ohm?
ur probably clipping it if you have it wired to 2 ohm
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
to much power on the sub.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
how should i fix the clipping since i just set it with a multimeter?
Erm.... did you use 0.5 ohms when calculating the gain?
Set it as if it's 1 ohm. Your amp doesn't make fuck all more power @ 1 ohm.
You're clipping the tits off it, I bet. What voltage did you set it at?
10.x volts fo' life!
  • Who's Online   1 Member, 0 Anonymous, 1849 Guests (See full list)
