Ok when my sub is turned up really loud I know it is not bottoming out. I am pretty sure it is clipping. I will turn it up and on the high notes it just sounds normal, but on the really low low's, it starts to pulse on whatever tone it is on. kind of like a soft popping sound...This is clipping right? Which means the amp is pushing all it can and is not getting enough power to it or something right? Does that mean the sub can still handle more power if it is not bottoming out yet? Maybe I should get a bigger in line fuse?
Edited by Cpl Dozier
www.AlabamaDrift.com04 Silverado in the works
clipping is nothing more than audible distortion caused by your power to peak power being exceeded. (amp is working harder than it should, could be a voltage problem) turn your amp down a bit and it should disapear...
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
You xxx will never bottom out, its impossible, could also be the amps inability to play that freq. Say 15hz, some amps are not able to play down that low. (safely)
Like roscoe said Id turn down the gain just a hair and see if it goes away.
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
