1030tooled Posted January 29, 2010 Report Posted January 29, 2010 I really don't see how you can figure the tune of the box as if it were in an open feild,....when it will be in a car? 93' Ford Aerostar Alpine head unit 4-5.25 MB Quarts 20-10" pyramids super Pro 1 Lanzar amp
Ludachris5150 Posted January 29, 2010 Author Report Posted January 29, 2010 id say that port area is dependant on what you want out of it in the long run theres no RULE that it needs to be 16max, ive in certain cases done 18-20sq in per cube furthermore other then your sig, we have no ideas whatsoever what amp youll be running on the subwoofer, that being another determining factor. As well as what kinda music you listen to and if your looking for loudness or controlled sustained sound. IMO without those answers nobody can really say that you have to much or to little port area or even box size for that matter. Ok to be a little more detaild. The box that the Q is currently in is .6^3 over 4^3 which is FI's max ported. So I want to build a box thats right for the sub. No competing, Or anything like that. I will be using the AQ1200D. Mainly listen to rap but I still want it tuned to 31-32hz (I love the lows). Im looking for loud and low basically. Sorry to keep changin the dimensions, This is what I came up with! And no my pic isnt how the box is gunna come together... Jus mockd up a box with the paint program. You should allready know from looking at the specs tho Rebuild in progress...
Ludachris5150 Posted January 29, 2010 Author Report Posted January 29, 2010 I really don't see how you can figure the tune of the box as if it were in an open feild,....when it will be in a car? What do you mean? Im using exposports calculator, Using my trunk dimensions... Rebuild in progress...
AI James Posted January 29, 2010 Report Posted January 29, 2010 Ok to be a little more detaild. The box that the Q is currently in is .6^3 over 4^3 which is FI's max ported. So I want to build a box thats right for the sub. No competing, Or anything like that. I will be using the AQ1200D. Mainly listen to rap but I still want it tuned to 31-32hz (I love the lows). Im looking for loud and low basically. Sorry to keep changin the dimensions, This is what I came up with! And no my pic isnt how the box is gunna come together... Jus mockd up a box with the paint program. You should allready know from looking at the specs tho make sure you calculate the area the 45s will take up and whatever bracing you use before time, as they do take up more then youd generally think. imo 3.5 cubes net after all bracing and 45s with about 60 sq in of port should do well. yea its a little over 17 per cube but in your application it should be more then fine considering your wanting it loud and low. the 32hz tuning should be fine as well... what kinda vehicle is it in also
Ludachris5150 Posted January 29, 2010 Author Report Posted January 29, 2010 make sure you calculate the area the 45s will take up and whatever bracing you use before time, as they do take up more then youd generally think. imo 3.5 cubes net after all bracing and 45s with about 60 sq in of port should do well. yea its a little over 17 per cube but in your application it should be more then fine considering your wanting it loud and low. the 32hz tuning should be fine as well... what kinda vehicle is it in also Its goin in my 92 cadillac deville. I dont know how to find the displacement for the 45's either? But I wouldnt think itd bring me from 3.96 to anything under 3.5. Thats pry all the bracing Im gunna do tho. So besides the 45's displacement does it look ok? Someone told me the total port length of 21" isnt enough for 32hz? Fuck Im getn frustrated, I jus want to get it done, But at the same time do it right the 1st time u know. (the port is 3.5" wide also, Forgot to mention that up above) Rebuild in progress...
AI James Posted January 29, 2010 Report Posted January 29, 2010 your 45 displacementy is going to be dependant on if you mathematically place the one in the port or you just eyeball a 45 into there if its proper then find volume for one hxwhxd divided by 2 will get you the volume of one multiply that by how many you do divide by 1728 to get cubic feet displaced and theres your displacement for 45s if you use dowels pi times the radius squared times length of dowel gives you the area of that divide by 1728 to get cubic feet displaced
Ludachris5150 Posted January 29, 2010 Author Report Posted January 29, 2010 your 45 displacementy is going to be dependant on if you mathematically place the one in the port or you just eyeball a 45 into thereif its proper then find volume for one hxwhxd divided by 2 will get you the volume of one multiply that by how many you do divide by 1728 to get cubic feet displaced and theres your displacement for 45s if you use dowels pi times the radius squared times length of dowel gives you the area of that divide by 1728 to get cubic feet displaced Cool, Thanks... So Besides does it check out? Port length and everything? Rebuild in progress...
AI James Posted January 29, 2010 Report Posted January 29, 2010 cant tell you until the other measurements are accurate
Ludachris5150 Posted January 29, 2010 Author Report Posted January 29, 2010 cant tell you until the other measurements are accurate Idk... Fuck it I guess, These calculators are bullshit. Guess Im jus goin to have to pay for someone to get me a correct design. Rebuild in progress...
esteagall Posted January 29, 2010 Report Posted January 29, 2010 i would go with the second design and if you double baffle it it will not change anything. should sound good -Car: 2006 Ford expedition King Ranch -Subs: 2 FI BTLs 18 fully loaded -amps: 2 sundown SAZ 3000D -Alternator: DC Power 260 amps -Batterys: 2 optima yellowtops -A whole shit load of 0 guage knu hyper flex and raptor cable -Rockford Fosegate 3sixty
