sorry your dimensions are wrong internal dimensions are 34.25 wide x 22.5 high x 14.5 = 11174.0625
whoops must have misread the dimensions. So its 6.05ft^3 after displacements the tuning is going to be higher then the calculator says because of the volume difference. It will also be higher with the 45 in the port shortening the port length.
the 45 doesn't shorten the port length at all, the 45 keeps the port the same all the way through.
So ill add .25" to the height and the port, that way it lowers my tuning, and gives me a bigger net air space inside the box.. calculator reads - 6.22 cubes @ 32.14 and when i double baffle it, it will also pull my subs up .75" (but the extra i gain from that will equal out when i brace it)
Edited by Hostility
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
anymore input?
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
anymore input?
ok, talking to torres, i had the port backwards, so this is what i have come up with to be about the same, how does this look now?
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
  • Who's Online   2 Members, 0 Anonymous, 1294 Guests (See full list)
