All angry responses will be accepted because I acknowledge that this is a somewhat of a newb question.
Is it okay to use a 1-ohm amp on subs that are at 1.3 ohms?
Yes you can but you won't get the power the amplifier is rated to give out at 1 ohm and impedance rise will rise it moar??
Basic Amp Tips:
Get a good amplifier.
Never use bass boost.
Match your gain to your headunit's pre-out voltage (just because gain is at half doesn't mean it's at half volume unless your preout is really 0.2v or something.
Use good power cables.
Edited by calvin_115
Mids/Highs: stock Bang & Olufsen
Lows: Image Dynamics IDMax 12v.3
Power: Sony Xplod XM-D9001GTR:Knukonceptz 4 gauge
Box: 1.75 cu/ft Sealed
Past: Pioneer Premier TS-W1207 (2)/ Rockford Fosgate P210/ Image Dynamics ID10V.3/ Infinity Reference 311A/ Audiopipe AP-18001D
dont worry about it bro. 1.3 ohms will be fine. with box rise your probably gonna let the amp see like 3-4 ohms anyways
so a 1 ohm amp is a-okay?
Buddy, can you read the posts?
x2. anyways, just because you have subs wired to 1 ohm on a 1 ohm stable amp, those subs will BARELY ever (99.999% of the time) ever reach 1 ohm. it will always be higher.
Basic Amp Tips:
y not use bass boost??
1995 Integra GSR (DB8)
Pioneer 3200-DVD
6.5 rockford fosgate 2-way fronts
6.5 rockford fosgate 3-way rear
saz-3000D
(2) 12" SA-12s
