With a tone you can play right at your peak freq,
but how much gain depend. i get the same score with a song that peaks right where my car peaks
you will also have more impedence rise with a tone
i guess ill give one a try next comp i go to
that's the only real way to find out. I gain .9dB's and another guy on my team only gains .3dB's. I've heard of set ups gaining 1.5 or more, but I assume they aren't playing the right song...
True, but you also get more power out of your amp with tones, since it is not dynamic like music is.
So like others said before you can gain a 1/4 DB or even up to 2 or 3 Db's in some situations.
¿ǝɯɐƃ ǝɥʇ
well if u are referring to using a 0db sine wave then it should always be louder since its constant it allows the pressure to build easier
and at 0db u are going to get the most power out of the amp before clippage
whereas most music resides in the -10db to -5db usually
(hence why my gain setting test tone is -4.6db, this gets music as loud as possible while still having some room for safety)
there are plenty of songs tho that hit for 1-3 seconds at one frequency at 0db, so it also has to do alot with song choice
okay it sounds like a tone will be my best bet. Im not sure what frequency to play. I can pretty much tell by ear what sounds loudest though
6 Sundown X 15s
2 Sundown NS1 V2s
C Pillar 4th order
Bagged Suburban on 24s
http://youtube.com/tlee333
If you are doing a comp, most of the time you will be able to play a sweep and they will tell you at what Hz you where loudest at.
¿ǝɯɐƃ ǝɥʇ
