uhoh_45 Posted February 5, 2010 Report Posted February 5, 2010 (edited) my firefox has been all wonky laitly and been freezing up on me over nothing and after getting real pissed i figured i might do something about it i went to my add on's and found 3 things there and im not sure exactly which ones i can disable now i know i can disable skype and the tvu but i donno what the first one is for and googled it and everything said disable it or uninstall it because its bad or some shit so any info on this would help edit what can i get rid of here ? Edited February 5, 2010 by uhoh_45 Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
treossi Posted February 5, 2010 Report Posted February 5, 2010 i'v heard the first one is wack, the only thing i use as far as mozilla plug ins are add blocker... it's great to not see websites with add's .. no names, and also pop up blocker what does the tvu do, online television ? Quote Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
uhoh_45 Posted February 5, 2010 Author Report Posted February 5, 2010 i donno it was for a ufc i wanted to watch online but never got working im probability going to delete it seeing as how i dont use it Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Baydestrian Posted February 6, 2010 Report Posted February 6, 2010 Those shouldn't cause any problems with your browser... Why is it exactly doing? Quote 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
