subs are dual 2 ohm amps are 2 audiopipe 3Ks
pic becasue i dont really know how to explain it lol
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
im gonna say yes but no recomended. it wont really divide power and could possibly feed back into other amp and go into protect. thats my bet
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
wont work
Try a sub and a coil on each amp.
but unless they are strapped or master/slave you'll fuck something up.
84 K5 Blazer
3" body, 2" Suspension
35" Maxxis Bighorn
100amp Alt
Marine deep cycle for the amps (freebie)
KnuKonceptz 1/0
8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz
Audiopipe AP-18001D
RF 5x8's in the kicks
Almani 5.25 comp. in back
Kenwood KAC-645
--IN THE FUTURE--
None.
<!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
cant you just run each amp to 3 subs at 1.3 ohms and have battery power supply to back her up and hope imp rise brings her up past 2 ohms
R.I.P!
(Nov-29-2009)
92 explorer
current build
well my suggestion is to get a 3rd amp. or just do 2 subs.
Essentially you are tying to use 2) 2channel amps (total of 4 channels)
On 3) dual coil subs. (6 coils)
There is no way to properly do it and work to full power potential and reliability.
And the diagram above would have the woofers working at different impedances and the amp would feed into eachother causing damage.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
will not work
im only 16 and i will be the first to admit that i do not know everything but the way you have it only the outer 2 subs will fire because they make a full circuit middle one will not because + and - are not connected and do not close the circuit.
i may be wrong but that is my thought
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
i know its possible to do it if they are wired in parralel and each amp powers 3 out of the 6 coils but i cant do that with my amps as there only 2 ohm stable and each would be under 1 ohm im pretty sure
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 502 Guests (See full list)
