18" Custom dual 0.45ohm 1500rms
I needed to get rid of some parts, that I WONT part with, I will only build up with, so I decided to build up a woofer using a heavy gauge 17.5 gauge, 4 layer copper wire coil, dual 0.45ohm, 2" winding width-
Triple 9" spiders, and stiff surround, and heavy duty cone.
This beast isnt based on excursion, but just LOUD Low end bass response, a great bass racer sub, or someone who likes to go low
I can build one more of these on request, the parts are readily available
This sub shows a very high efficiency that I don't even believe, yet its just a calculated eff of 101db with a Fs of 26hz
I would like to think its more closer to 94db
Also, used is Knukoceptz 8gauge for direct leads
Here are some pics
Asking $300 each, and will cut a deal shipped, or if your local pick up, you will get a great deal
Is that a Mojo motor that was used to build the sub?
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Maybe.....
I did used to work for them....
I cant sell the baskets, they are bolted up to the motors already, ready to build complete subs. I make no money selling the baskets
bumpity bump
I'm curious if you would build this same setup into a 15 with an 8 layer flat wound aluminum coil? The reason why I am aksing is because my team captain is looking at running a pair of Mojo's in his Cavy that he did a 153 in before with the setup in the trunk. Since these are the same motors and you have parts to build them into pretty much whatever he may be interested in buying a pair of 15's from you. He ran the quad 1 ohm Mojo's before so I'm not sure exactly what impedence he would need since there are quite a few options with that coil configuration. If you can do it I'll talk to him and see if he's interested in doing something.
1 XS Power D3100
Audio Control LC6i
Stock Deck
PM'd
Thursday Bump....
Loacals come pick up, or listen to
