I DONT GET IT IM ABOUT TO SELL IT ALL!!!!
Batterys work together, im actually going to draw you a picture since your not understand what were saying.
And to Neo, running a separate run of 1/0 from front to back is not necessary in this case. Also his car is Unibody so there is no "frame" per say
Both batterys are to be grounded to the body of the car
I was referring to dropping the distro blocks and chassis ground altogether, not adding another wire.
Need an install? Hit me up.
[email protected]
Got car audio questions? Check here first!
Everything you need to know. =]
http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
And for the record, electricity flows from negative to positive in this application.
[email protected]
Correct
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
Just curious man, but why don't you just actually try some of the suggestions you are getting instead of just repeating the problem over and over and over? :P
'05 CHEVY TAHOE
Pioneer N4 | 4- MEMPHIS M3 12's ..... 2 DC LVL 4 XL's ON THE WAY | 1- MEMPHIS MOJO 4k | 2- Optima Yellow Tops
Ohio Gen 295A Alt | Kicker 1/0 Wires, RCA's, & Connections | BIG 3 | SECOND SKIN SPL TILES
secondskin_728x90.gif[/center]
well what kinda alternator dose he have ??
105amp. He shouldn't try pushing more then 1000wrms on a 105 amp alt. Your alt cant keep up with the load demand. Upgrade the alt and you should be fine.
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
ok i did a quick short vid im uploading it now
and i am listening to what everybody has to say
alt
big 3
check door speakers for blown speaker
reset all gains
relocate grounds
ill post the vid as soon as i have it up and running
see if it will help any
I run 2KW+ on 105A alt, just gotta let it charge up sometimes.. and not run it all out all the time ;)
Hammerdown... 1%
  • Who's Online   1 Member, 0 Anonymous, 778 Guests (See full list)
