Common Chamber or Separate Chambers
Maritoze
I have two Memphis M3's and I want to give them about 2cubes each after displacement. I want a slot ported box tuned to about 40 hz...Should I build a common chamber enclosure or separate the chambers? Is there a difference in doing so? Any help is appreciated. Thanks.
in a seperate chamber its good cause it will have good bracing. in a common chamber you will have more cubic feet. if space is not a issue i would do seperate chambers because the box would be stronger but dont give up cubic feet just to go seperate
6 Sundown X 15s
2 Sundown NS1 V2s
C Pillar 4th order
Bagged Suburban on 24s
http://youtube.com/tlee333
you can still have the cubes of feet with the common chamber and do the cross bracing inside it to. look at the inside of steve meades box. 1 big chamber with lots of bracing in it. and a HUGE ass port lol :hairtrick:
tune a bit lower, those m3s are happy at 36ish IME
if u build a common chamber and one sub blows u cannot use the other speaker til both are working whereas if u built separate chambers u can at least play one
personally id rather have a common chamber, its usualy is louder/more efficient because u dont have to worry about making two perfectly identical boxes or internal volumes... id much rather brace it with dowel rods and get the most amount of space and port i need
depending on where the port is there is a benefit to do port down the middle, this adds alot of strength but again u have to be pretty much perfect with port lengths, 45s ect
unless im asked i always make a common chamber box well braced
o lulz, wrong
his port is tiny!!!!
thats why he can throw gobs of power to them, he has lots of cone control with a small box and small port
you can make a common chamber work, me, personally, have always liked seperate chambers. You can always make a common work with any cubic feet, all your doing is sharing one chamber and one common port. (generally)
Behind every great man....is an underwear tag!
  • Who's Online   0 Members, 0 Anonymous, 2855 Guests (See full list)
