Thenumber1z Posted February 12, 2010 Report Posted February 12, 2010 I'm running 4ga Raptor wire to my sub amp. Should I change it or is it one of the better brands? 1991 Nissan 300zx JVC KD-HDR50 (2)Kicker L7 10's Custom enclosure(Entire hatch) Hifonics 1606D (Subs) Kicker 650.4 (Mids & Highs) Hifonics ZXi 5.2C (Front) Kicker 07DS600 (Rear)
loganberry Posted February 12, 2010 Report Posted February 12, 2010 your running it as power to the amps or power from your amp to the subs? if its from amp to the subs its fine even tho its raptor which sucks, 4 gauge for what you have is hella overkill, 4 gauge in general is overkill, but overkill is nice My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
Thenumber1z Posted February 12, 2010 Author Report Posted February 12, 2010 No see that's the thing it goes from battery to amp. Should I get rid of it? 1991 Nissan 300zx JVC KD-HDR50 (2)Kicker L7 10's Custom enclosure(Entire hatch) Hifonics 1606D (Subs) Kicker 650.4 (Mids & Highs) Hifonics ZXi 5.2C (Front) Kicker 07DS600 (Rear)
joni13 Posted February 12, 2010 Report Posted February 12, 2010 i would i have had some of the raptor wire and imo they suck get some knu 1/0 like 1.75 a foot its cheap and WAY better than that raptor RIP The 03 prix! New Ride 2003 Chevy Tahoe Z71 4 DC LVL 4 18s (2 currently installed) 2 DC PAI.2000 (1 currently installed) 1 DC PAI-120.4
Thenumber1z Posted February 12, 2010 Author Report Posted February 12, 2010 Would I notice a difference by changing the wire.? 1991 Nissan 300zx JVC KD-HDR50 (2)Kicker L7 10's Custom enclosure(Entire hatch) Hifonics 1606D (Subs) Kicker 650.4 (Mids & Highs) Hifonics ZXi 5.2C (Front) Kicker 07DS600 (Rear)
J00bles Posted February 12, 2010 Report Posted February 12, 2010 Would I notice a difference by changing the wire.? you might. depends on how much you've starved the amp with that raptor. 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
CaptainzPlanetz Posted February 12, 2010 Report Posted February 12, 2010 The Raptor 4 gauge is more like a 8 guage, I would say it is comparable to Boss Wire. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
ISO Posted February 13, 2010 Report Posted February 13, 2010 Would I notice a difference by changing the wire.? 1st let me say that I agree with everyone here. You need better wire. Now to your question. Do feel like your amp runs a little too hot the majority of the time? Does your amp get hot fairly fast? Do you suffer from thermal overload which kicks in the protection circuit to shut the amp down? 3 tests. Setup for the test: With you engine turned off but your stereo left on and your radio set to CD mode eject the CD and don't let it go back to radio and if you can't do that then just turn your volume all the way down. Test 1: Use a DMM and check your DC voltage at the battery and see what it says. (Example would be 12.5 volts DC) Then go back to your subwoofer amp and use the DMM on your power and ground inputs on your amp and see if you have a different voltage like 12.1 volts DC. Then go back to the battery and make sure it is still staying at your original number. Our example is 12.5. as long as you are quick enough the battery should still say 12.5 or 12.4 as the car accesoraries are pulling some current. Make sure to turn off your heater blower and anything else that pulls current. This is called voltage drop. If you have it then definetly get better power wire for sure. Test 2: Same as above but do it with the engine running and it might be better to do this test this away first instead of leaveing your engine off. Test 3: Use a continues test tone (while the engine is running) at 1/3 to 1/2 of your volume. Just not enough volume that you know you are pulling alot of current and do the same test. Check at the battery. Then check at the amp. Then check at the battery again. Sorry for all the options here but it has been so long since I have needed to find voltage drop that I am a little fuzzy remember the propper way to do it. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
