fox_racin4 Posted February 18, 2010 Report Posted February 18, 2010 ok so ive never really messed with amp settings only used the gains on them all the other filters are down all the way will adjusting the lpf make it anylouder or will it just help get the higher notes? how do i set the lpf? 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
k3n12ock Posted February 18, 2010 Report Posted February 18, 2010 ok so ive never really messed with amp settings only used the gains on them all the other filters are down all the way will adjusting the lpf make it anylouder or will it just help get the higher notes? how do i set the lpf? My LPF is at 70/75 and subsonic at 27/28 or somewheres in that area Best bet, play it and tune it to your liking as everyone has different taste. 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
HHR Ed Posted February 18, 2010 Report Posted February 18, 2010 LPF wont have anything to do with getting louder, but it can make you quieter if set wrong. Most subwoofer systems play 80 hz and lower. So it should be set to 80hz, this will cut out all frequencies above 80hz. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
fox_racin4 Posted February 18, 2010 Author Report Posted February 18, 2010 alright i dont like the ssf i just be carefull with what i play so really the only adjustment "needed" is the gains? 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
kylecm85 Posted February 18, 2010 Report Posted February 18, 2010 You really need to adjust your lpf because you are missing alot of frequancy's that you dont even know are there. So put your lpf on 80hz and it will be good and you will be surprised how much more musical it will be. 94 lincoln mark viii h/u: kenwood kvt 614 Excelon comps: alpine type x amps: mtx 1501d mtx 4004 sub:2 DC lv4 12 wiring jl audio 0awg 8 awg sub jl audio 4 awg for mid and highs amp myspace.com/kylecm85 carstereolexington.com
fox_racin4 Posted February 18, 2010 Author Report Posted February 18, 2010 alright so how will i know if its on 80hz? or around there also ill be runnign 2 amps again shortyly one on each sub how will i know if both amps are set the same? i know how to gain match them but not set the lpf 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
