groundpounder2k2 Posted June 9, 2007 Report Posted June 9, 2007 as you know ...this is my enclosure....its sealed........ while I was digging around in the attic of the carage.........I found this old thing.. Its left over from back when I had my Beretta...Id run four 15s sealed for daily...and at showtime Id pop out two subs and drop in 2 of these to make it a Meter Beater..So no im wondering if i could do the same with the Cavalier.But i havent a clue.....as to how Id figure it all out....ie.......how big the ports have to be....how long the ports have to be..... So...........enclosure designers......what info do you need from me........in order to halp me figure this out.... Tim My MainMan,My lil Man,Dude,Bubb....My son Memphis @ 3years OldShow'em that car son..........
LSN2meBoom916 Posted June 9, 2007 Report Posted June 9, 2007 1:NET Airspace inside the enclosure (having subtracted the 4 woofers, bracing, and Port volumes-assuming you're gonna have 2 ports & 4 subs)-however once you lengthen/shorten them ports (if u do) their volume will have to be recalculated in/out. 2: Desired Tuning freq. Pretty much it I think (anyone correct me if I missed anything) Basically once you know exaclty how much AIRSPACE you have avail, you can change the port length (usually area TOO but in this case NOT SD/area...only if you weren't set on using those ports you could) to achieve a certain tuning freq. and hopefully you have around 16in^2 per ft^3/volume or you could have port noise. COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
groundpounder2k2 Posted June 9, 2007 Author Report Posted June 9, 2007 I will be making new ports to drop in the woofer holes....I just showed them pix as an example... My MainMan,My lil Man,Dude,Bubb....My son Memphis @ 3years OldShow'em that car son..........
Forevrbumpn Posted June 10, 2007 Report Posted June 10, 2007 or if you have a way to meter, like a rta, or termlab, you can do a guestimated port, test it, then cut as needed to change port tunning. but start off with the longest, largest area port possible, then cut down from there... that port looks about right for 4- 15s tho. damn i hate working on sundays I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
