uhoh_45 Posted February 20, 2010 Report Posted February 20, 2010 Um I'm thinking this is spam because it looks like he photoshopped some really crappy speakers into the picture to make them look big considering they arn't sitting in anything your retarded- as for OP are you using one or 2 subs if only using one sub its going to be hard to find a powerful amp that puts out the power at 4 ohms now if your using both subs you can wire them down to 2 ohms which you'd be good going with a solid 3k amp at 2ohms and with your budget an audiopipe 3k would be your best bet Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Baydestrian Posted February 20, 2010 Report Posted February 20, 2010 ^I guess you missed where he says What kind of amp should I use for one Quote 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
86Wrangler Posted February 20, 2010 Author Report Posted February 20, 2010 your retarded-as for OP are you using one or 2 subs if only using one sub its going to be hard to find a powerful amp that puts out the power at 4 ohms now if your using both subs you can wire them down to 2 ohms which you'd be good going with a solid 3k amp at 2ohms and with your budget an audiopipe 3k would be your best bet The Box is going to be way too big. I can only fit one in the bed of my Truck. Whats better the audiopipe 3k?? Or a Hifonics Colossus?? For one sub? Quote Current set up Subs: (4) B&C 6's Amp: (1) Clarion 4 Channel 640watt Headunit: JVC KD-R800 Electrical:Stock Box: Custom built out of 1'' Russian Birch Wire: 4 gauge wire Next Set Up (Adding to what I have) Subs: (2) Celestion Vintage 30, (1) 21'' B&C Amp: So far Legacy Predator 4000 watt. (Looking for a colossus) Wire: 1 Gauge Electrical: (4) Gel Batteries, alt out of a Ambulance Box: Designed not built yet
Boon Posted February 20, 2010 Report Posted February 20, 2010 Um I'm thinking this is spam because it looks like he photoshopped some really crappy speakers into the picture to make them look big considering they arn't sitting in anything Welcome to Idiotville, population: you. OP, you're better off running a dual monoblock as mentioned or a pair of smaller amps like the Sundown SAZ-1500D - this way the amps will see 2 ohms each and make more power. Running a big-ass amp at 4 ohms is kinda stupid. Stetsom might be a good option here... especially if you got one or 2 of the '2 ohm' option amps Quote 10.x volts fo' life!
86Wrangler Posted February 20, 2010 Author Report Posted February 20, 2010 Thank you Everyone for your help. Quote Current set up Subs: (4) B&C 6's Amp: (1) Clarion 4 Channel 640watt Headunit: JVC KD-R800 Electrical:Stock Box: Custom built out of 1'' Russian Birch Wire: 4 gauge wire Next Set Up (Adding to what I have) Subs: (2) Celestion Vintage 30, (1) 21'' B&C Amp: So far Legacy Predator 4000 watt. (Looking for a colossus) Wire: 1 Gauge Electrical: (4) Gel Batteries, alt out of a Ambulance Box: Designed not built yet
