terminal screw broke off in battery!!!
sooo i made a new set of terminal screws for my battery becuase i only had one! and when i was screwing it in it broke clean off!!!!! flush with the top of it soo i dont know how to get it out!!!!!!
wiht the screw in it!
what it should look like!
"yes... it will play like that all day!"
they make a tool i think its called an easy out you dill a hole with a drill in reverse and then you flip the bit over and use the other side and it backs out the screw out or you can cut a lil slit in the top of the bolt and just big enuff for a flat head screw driver and use that
edit :http://homerepair.about.com/od/interiorhomerepair/ss/screw_extractor.htm
Edited by fischy fisch
lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
how do i cut a slit in it???
i see no good resolution coming from this at all.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Use a dremel with a bolt cutting bit to sink a small slit in it. And as said, use a screw driver to turn it out.
If you torqued the shit out of it (which I'm guessing you did) then you might have to drill it out and retap it.
Need an install? Hit me up.
[email protected]
Got car audio questions? Check here first!
Everything you need to know. =]
http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
no the bolt wasnt even all the way in! it got a little tight but not to wear i need to hands!
so you cross threaded it more than likely
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Guest Scylloga
no the bolt wasnt even all the way in! it got a little tight but not to wear i need two hands!
Ummm you should never need two hands to tighten a battery bolt. If you are using two hands you risk doing exactly what you did.
