Subwoofers that face each other.
What is a good rule of thumb when building an enclosure in which you have subwoofers facing each other. I imagine there is a minimum distance that they need to be a part. How is tuning, spl, sound quality affected with this distance?
Thanks in advance!!
Warm Regards,
Dyno Brian
1997 Ford Probe
|Sony Head Unit|Alpine V12 AccuClass-D MRD M1000 Amplifier|4 RE AUDIO SRX12D4 12's|Mids and Highs coming soon!|
|1998 Mustang GT Twin Turbo|1986 Mustang GT Single Turbo|1996 Mustang Mystic Cobra N20|1995 Mustang Cobra 5,000 miles|
2002 ZO6
i dont think anyone has specifically calculated it....try to keep them as far apart as possible unless its a bandpass i imagine....
DCAUDIO
BALLS DEEP
Your enclosure brings up another question. It would seem that having 4 subs firing at each other would cause some type of cancellation of sound waves. I am probably wrong.
The reason for these questions is I am getting the itch to do something with one of my trucks. I am considering doing a blow thru with my ranger. Not sure I am willing to take a saw to my diesel.
Warm Regards,
Dyno Brian
1997 Ford Probe
2002 ZO6
I have my subs facing each other just slightly off angle and it's the loudest to the ear I've heard in my car...
[HOONIGAN]*
'01 Ford F-250 LWB
JVC KD-R950BT / Alpine MRV-M500 / (2) SWA-10s4
its a compromise. im sure a flat wall with the same given cone vs a bass tunnel will be louder avoiding said problems, but a diamond or tunnel has a half ass bandpass effect all in its own.
DCAUDIO
BALLS DEEP
It depends what you're trying to achieve. Generally you need to have them far enough apart that the space between them doesn't act as a port/chamber - this means the opening should have an area greater than the combined piston area of the woofers inside it.
10.x volts fo' life!
Good to see you made it on here Brian. This is 351lightning on CR. Don't really need to much space. Diamonds and tunnels (sp?) builds are within 12-18inches apart. If it's a build like chickens hoopty you could get some effects of a sixth order bp. Clamshell it if you are low on space.
  • Who's Online   0 Members, 0 Anonymous, 1619 Guests (See full list)
