BeachJoshua Posted February 20, 2010 Report Posted February 20, 2010 Okay so I'm running my 4 kicker comp C12 12's off of 300 watts RMS, they're rated for 150 RMS, how much, if any, do I risk? the box is tuned to around 33 to 35 Hz, I listen to rap, like Gucci, Yo Gotti, Jody Breeze etc.... | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
TeejayBee Posted February 20, 2010 Report Posted February 20, 2010 Your running each at 300rms or just 300rms for all of them to go off of?
Jared420 Posted February 20, 2010 Report Posted February 20, 2010 Okay so I'm running my 4 kicker comp C12 12's off of 300 watts RMS, they're rated for 150 RMS, how much, if any, do I risk? the box is tuned to around 33 to 35 Hz, I listen to rap, like Gucci, Yo Gotti, Jody Breeze etc.... I dont think your really risking much but I would definatley get more power. considering 600 rms would be ideal you could have am amp do that for very cheap. unless you mean 300 rms per sub, then i would make sure your gain is set properly and you are giving the subs clean power. as long as your giving them a clean 300 rms those subs should be able to handle it. 2012 silverado ext cab ltz 24" kmc rims AudioQue 2200 Pioneer AppRadio Alpine mrx f35 4 channel Bose mids and highs Iraggi Alt + stock alt in a DC power dual alternator kit Yellowtop+stock under hood 0 gauge Knu wire Big 3 4 gauge stinger (4 chan wiring) 3 DC 10'' LVL3 with LVL4 parts
Mosin Posted February 20, 2010 Report Posted February 20, 2010 I dont think your really risking much but I would definatley get more power. considering 600 rms would be ideal you could have am amp do that for very cheap.unless you mean 300 rms per sub, then i would make sure your gain is set properly and you are giving the subs clean power. as long as your giving them a clean 300 rms those subs should be able to handle it. X2 Don't abuse your gains and you'll be fine.That's if your running 300rms per. 300Rms total or per youll be fine Derp.
BeachJoshua Posted February 21, 2010 Author Report Posted February 21, 2010 X2Don't abuse your gains and you'll be fine.That's if your running 300rms per. 300Rms total or per youll be fine Amp does this... 600 x 1 RMS at 1 Ohm, and 2 Ohm 300 x 1 RMS at 4 ohms... I running 4 subs on it, they're gonna be puttin a total of 4 ohm load on the amp... every sub will get 300 RMS.... | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
kmalinich Posted February 21, 2010 Report Posted February 21, 2010 Amp does this...600 x 1 RMS at 1 Ohm, and 2 Ohm 300 x 1 RMS at 4 ohms... I running 4 subs on it, they're gonna be puttin a total of 4 ohm load on the amp... every sub will get 300 RMS.... whoa, nooo... how are you wiring these? what ohms are the subs? and if you have 4 subs, making a final ohm load of 4 ohms, and you have it hooked up to the amp, it'll be 300 \ 4 ... so each amp would get 75w...
Audiosavings Sam Posted February 21, 2010 Report Posted February 21, 2010 Okay so I'm running my 4 kicker comp C12 12's off of 300 watts RMS, they're rated for 150 RMS, how much, if any, do I risk? the box is tuned to around 33 to 35 Hz, I listen to rap, like Gucci, Yo Gotti, Jody Breeze etc.... The truth is it depends on which Brand your amp is. If you are running the 4 kicker compubs to a mono amp then the ampo should be 600 RMS not more than 900 RMS if it is a reputable brand. (Crappy off brand name brands rate their stuff differently) If you give me the model # of your amplifier and the Brand as well as tell me if your comps are 4 ohm or 2 ohm I will tell you if what you are doing makes sense and i will send you a wire diagram to show you how to wire it.
BeachJoshua Posted February 21, 2010 Author Report Posted February 21, 2010 The truth is it depends on which Brand your amp is. If you are running the 4 kicker compubs to a mono amp then the ampo should be 600 RMS not more than 900 RMS if it is a reputable brand. (Crappy off brand name brands rate their stuff differently) If you give me the model # of your amplifier and the Brand as well as tell me if your comps are 4 ohm or 2 ohm I will tell you if what you are doing makes sense and i will send you a wire diagram to show you how to wire it. JBL BP600.1 | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
BeachJoshua Posted February 21, 2010 Author Report Posted February 21, 2010 whoa, nooo...how are you wiring these? what ohms are the subs? and if you have 4 subs, making a final ohm load of 4 ohms, and you have it hooked up to the amp, it'll be 300 \ 4 ... so each amp would get 75w... How the hell does that make sense? | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
TeejayBee Posted February 21, 2010 Report Posted February 21, 2010 Okay what ohm are your subs is what we need to know you might of said it but i dont feel like looking and if your having a final load of 4ohm then your amp is only putting out 300watts rms so each sub gets 75wattrms not 300 if you wire them down to 1 or 2 ohms then you will get 150watts per sub If you don't get this, this is how we are getting the numbers Your amp does 600watts at 1 and 2 ohm so if you wire the subs down to a final load of 1 or 2 ohms you are getting what is said to be 600 watts you take the 600 divided by 4 since you have four subs then you get 150watts per sub. Now if you wire it to 4ohms your saying it will only put out 300 watts so then you take the 300 divided by 4 since you have four subs and you get 75 watts per sub that better? Edit: and since your subs are rated at 150rms then wire them down to 1 or 2 ohm because then you will be giving them the power they ask for.
