xtremeacoustiks Posted February 22, 2010 Report Posted February 22, 2010 Now we are building this box for 12-10" alphasonik 600 series subs and the subs that are in the angle position of the enclosure I'm mounting regular and the top row of four I want to invert, My question is, when I invert the top four do i need to change the polarity or change the phase from 0 to 180 or just run it normal....each row of four subs will be on a Alphasonik PMA1200DA Here is an unfinished pic of box www.bassproducers.com TEAMS TEAM BASSPRODUCERS, TEAM HERTZ (VA) *Ranger System* (4) 18" Kicker Comp (4) 10" Kicker Comp Dual Stinger Alts. (5) Rockford Punch 200's (2) Punch 100's *Outlander System*152.6 DB so Far* ( TXX-APX12W (2) AP-30001D'S (2) AP-2004'S ( APMB6'S (4) KHC2400'S
kl0wn Posted February 22, 2010 Report Posted February 22, 2010 I'm pretty sure you would just run them normal 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
MrSkippyJ Posted February 22, 2010 Report Posted February 22, 2010 Now we are building this box for 12-10" alphasonik 600 series subs and the subs that are in the angle position of the enclosure I'm mounting regular and the top row of four I want to invert, My question is, when I invert the top four do i need to change the polarity or change the phase from 0 to 180 or just run it normal....each row of four subs will be on a Alphasonik PMA1200DAHere is an unfinished pic of box My guess is change the phase, but that is just a guess. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
fritosaregood Posted February 22, 2010 Report Posted February 22, 2010 reverse the polarity. seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
98crewcab Posted February 22, 2010 Report Posted February 22, 2010 My guess is change the phase, but that is just a guess. change it 180, you want all the subs pushinbg the same way. the normal facing pushing out, then the inverted wired in reverse otherwise your just swapping air back and forth between the subs, instead of compressing air with all the subs forgot to add.....nice enclosure:) 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk!
uhoh_45 Posted February 22, 2010 Report Posted February 22, 2010 people who dont know the answer dont need to post for fuck sakes you could either wire them backwards or if your amp has phase switch it to 180 if you wire them all normal you'll have some bad phase issues R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
MrSkippyJ Posted February 22, 2010 Report Posted February 22, 2010 people who dont know the answer dont need to post for fuck sakesyou could either wire them backwards or if your amp has phase switch it to 180 if you wire them all normal you'll have some bad phase issues Sorry, didn't mean to upset you. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
uhoh_45 Posted February 22, 2010 Report Posted February 22, 2010 i came off as a dick my bad just sick of people not knowing the answer yet posting anyways R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
xtremeacoustiks Posted February 22, 2010 Author Report Posted February 22, 2010 thanks guys...I'll try the 180 phase on them...once I get it all done and put in I'll post a vid and some pics...taken the jeep to a meca show march 7th in roanoke va so I guess we will see how well she holds up www.bassproducers.com TEAMS TEAM BASSPRODUCERS, TEAM HERTZ (VA) *Ranger System* (4) 18" Kicker Comp (4) 10" Kicker Comp Dual Stinger Alts. (5) Rockford Punch 200's (2) Punch 100's *Outlander System*152.6 DB so Far* ( TXX-APX12W (2) AP-30001D'S (2) AP-2004'S ( APMB6'S (4) KHC2400'S
xtremeacoustiks Posted February 22, 2010 Author Report Posted February 22, 2010 change it 180, you want all the subs pushinbg the same way. the normal facing pushing out, then the inverted wired in reverse otherwise your just swapping air back and forth between the subs, instead of compressing air with all the subsforgot to add.....nice enclosure:) Thanks www.bassproducers.com TEAMS TEAM BASSPRODUCERS, TEAM HERTZ (VA) *Ranger System* (4) 18" Kicker Comp (4) 10" Kicker Comp Dual Stinger Alts. (5) Rockford Punch 200's (2) Punch 100's *Outlander System*152.6 DB so Far* ( TXX-APX12W (2) AP-30001D'S (2) AP-2004'S ( APMB6'S (4) KHC2400'S
