Box for my BTL
Symmetry9898
Hey guys, I been putting some thought into my enclosure as i am getting ready to start installing my system soon. I have an 18 inch BTL all options, i will be powering this sub with a Rockford T20001bd. My demensions as of right now are 22H x46W x 22D. Im thinking about tuning to arround 32-34 hz. My port dimensions are 20.5H x 8W x 26L. This should yield arround 8 ft^3 after port and sub (i think). It will be a slot port as well. Sub up, port back. Does this sound right to you guys? If yall have any suggestions, please feel free to speak up, it would be greatly appreciated. Thank you in advance...
Build in progress:
Kenwood DNX890HD
Rockford Fosgate White wolf RCA's
2 Rockford Fosgate T400.4 on RF fanatic q components (6.5 in the kick, 6.5 in the front doors, 5.25 in rear doors)
2 Rockford Fosgate T2500's on sub
1 Fi car audio Team 15 D1
XS Power D3400 and three D975's in the rear
Mechman Elite 370
Stinger power connections and cable
Did you use torres' calculator?....i came up with 8.31cu.ft. @36hz (switch the width and height numbers for slot ports)
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
yeah, actually i did, i have never really built a ported enclosure so i dont really understand all the science behind it. Why would i have to switch the width and the height numbers?
Build in progress:
Kenwood DNX890HD
Mechman Elite 370
***just to clarify...when doing a slot port to add in end correction, use the port height as the the distance from the box wall to the side of the port wall. switching the numbers will give you a different tuning, as port width will be longer in and it'll extend the tuning a lil further than it should
-that's what torres put as a reminder
i found that only applies if your port opening is positioned vertically...
what kind of vehicle is it going in ?
Trailblazer SS
Build in progress:
Kenwood DNX890HD
Mechman Elite 370
Any other bumps or advice? im still not 100% clear on what has been said.
Build in progress:
Kenwood DNX890HD
Mechman Elite 370
  • Who's Online   0 Members, 0 Anonymous, 5298 Guests (See full list)
