Which would you choose?
Gutta Trash
OK I have been out of the audio world for a while because of kids work, etc. but now getting back in and starting a build, my main problem is the brands have all been bought out and switched so on and so forth. So I was wondering which of these would you actually go with because when I quit messing around with car audio MTX was on the same level as legacy so you could not go by any of their specs. thanks for your opinions in advance.
By the way I can get these at roughly the same price (about $15 difference)
MTX
JUST OUT! BRAND NEW MTX ELITE TE801D 800 WATT RMS (APPROXIMATELY 2,400 WATTS PEAK) MONO-BLOCK CLASS D DIGITAL CAR AUDIO AMPLIFIER WITH TOP MOUNTED CONTROLS AND A BUILT IN HIGH POWERED COOLING FAN AND AMAZING FEATURES
FEATURES:
* approximately 2400 W peak output (MTX rates most of their amplifiers peak output at three times the RMS)
* 800 watts x 1 @ 2 ohm RMS
* rated with true world RMS ratings (no bootleg or fake power ratings, this amp is the real deal)
* CEA 2006 compliant
* highest end elite series
* one of the best MTX amplifiers ever ( this amp is more powerful than most DJ amplifiers)
* this amp is a massive monster!
* Adaptive class D circuitry
* full digital power supply for extreme efficiency
* MOS-FET power supply
* Mono amplifier (perfect for 1, 2, 3, or 4 subwoofers)
* Overload and thermal protection
* Speaker level inputs with signal sensing
* Internal cooling system make sure that amp stays cool at all times
* Active temperature monitoring to make sure that amplifier does not go bad even at high temperatures
* Variable speed fan built in
* easy to use and access control panel
* adjustable sound-reaction mode
* 2 Ohm stable
* adjustable low-pass crossover (24 dB @ 40-200 Hz)
* Subsonic filter (12dB @ 30 Hz)
* 4 ga. Power input
* built and based equalizer (12dB, 30-80 Hz)
* New Sleek black finish with chrome board in middle
* THD at 4-Ohm RMS Power: <0.5%
* Preamp Outputs
* Frequency Response: 20-200Hz
* Signal to Noise Ratio: 69 dB
MB Quart
MB Quart DSC2000.1D Class D 2000W Monoblock Car Amp NEW
* Discus Series Class D Monoblock Car Amplifier
* RMS Power Rating:
o 4 ohms: 500 watts x 1 chan.
o 2 ohms: 1000 watts x 1 chan.
o 1 ohm: 2000 watts x 1 chan.
* PWM (Pulse Width Modulated) MOSFET power supply
* Wired remote bass level control included
* LED power and protection indicators
* Tuned Bass EQ (0-9 dB bass boost at 45 Hz)
* Soft start sound
* Preamp RCA outputs
* DC, short, thermal, and overload protection circuitry
* Unbalanced RCA inputs
* Damping Factor: >180
* Variable input level control: 0.2V-0.6V
* Variable low-pass filter (35-250 Hz, 24 dB/octave)
* Subsonic Filter (15-35 Hz)
* Frequency response: 15-250 Hz
* Dimensions: 19.69"L x 9.45"W x 2.7H
* 1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
* 1-year Sonic Electronix warranty
On 4/20/2010 at 10:06 PM, 'cc_audio' said:
Guys are just like girls, once you've had 18 inches you don't go back.
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
Sub Amp- (2) PPI 5000BD.1
(2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
(2) 1.5" Bose Tweets
(1) JY 80 AH w/ new JY busses
(1) Duracell 750 up front
Apex Alternators 270
A.C. Delco 160 alternato
Id go with the mtx, legacy sucks dick so do not get that!!
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
the choice is not between mtx and legacy ^^^^^ read the post ..lol
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
mb quart (if im not mistaken) is the same manufacturer as hifonics and crunch... which is maxxonics.... both hifonics and crunch are both overrated... they dont do rated power... if you do some reading here.. youll find it to be true... but it is cheap for its watt per dollar ratio... if i was on a budget.. i would use the mb quart or crunch or even hifonics if i was on a budget... mtx loods good... but i would say it all depends on the application...
what are you planing to do? and what car is all this going into?
My first truck... My first Real build...
*Update 8/9/10 DC Power 270xp Alt is In!!!*
1997 Toyota T-100 DC Level 5 18" in a T-line
Everybody wants their system to be....
1. Cheap
2. Reliable
3. Loud
...you can only pick two.
micahmye hertz pack
This is going into this build http://www.stevemeadedesigns.com/board/index.php?showtopic=70675&st=0&p=979838entry979838 wanting to push 3 12's (1000-3500 watts, Pioneer pro comps 2ohm dvc)
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
what I really need to know I guess is which company produces the best amp
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
Reading > you
To the OP, I would personally go with the MB Quart. I do not have any experience with either of them but from what I have seen and heard the discus amps are solid amps.
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
rockford all the way i no its not included in the top but they have the best amps or audioque
If I had the budget I would go that route but unfortunately I do not that's why I am trying to get help on these 2 amps
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
id rather have the discus
mtx still makes amps, lol, eww
mtx is 800w rms, discus 1000
mtx has 30hz subsonic, discus has variable
mtx has 4g input, discus has 1/0
mtx is .5% thd at 4 ohm, which means worse the lower u go
mtx only 2 ohm stable, discus 1ohm
mtx has no bass remote (if u like them), discus does
do i need to go on?
