gonna try something i read on teh interwebz 2morrow, its a voltage mod similar to the MLA mod but only for a few cars, i have a ALT that the regulators are controled by the car computer, im going to put a diode on the sensor line so it sees that the alt is producing less voltage, therefore it steps it up, going to try this on a bench alt first if no problems going to move it to my car, will post pics when i do it and the results
Guest DC Power Rob
Your alternator isn't controlled by the PCM. Very common myth/misunderstanding about alternators. The only "TRUE" PCM controlled alternators are most Dodge/Chrysler/Jeep vehicles, where the PCM technically IS the voltage regulator and controls alternator output. There are other PCM integrated alternators, where the alternators regulator is excited and controlled by the PCM, but the internal regulator still controls output and voltage. There are also quite a few vehicles and types of alternators that are just activated by the PCM, but the PCM has no "control" over the alternator itself.
On your alternator, as most others with a "S" or sensing terminal, adding a diode inline just lowers the voltage the regulator sees at the "S" terminal and it over compensates raising voltage to what it thinks it should be. On some vehicles it works, some it doesn't, but 99.9% of the time I would highly recommend against doing what your doing because you can do more damage than what you stand to gain, especially with a stock alternator.
robbie, i did plenty of testing on the bench alt, and it worked fine, so i moved it to the car and it looks as tho its working fine running at 15.19v
pics time
before
diode
after
should hold me over till i get down to you at the end of march robbie
pics time
pretty interesting but wouldent this put shit loads of stress on your alt
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
it does stress the alternator, as the internal workings of the unit were not made to handle that kind of load over periods of time.
call me a dick for saying it, but after warnings form an alternator manu about why its not good to do and you still doing it...id probably laugh at the car catching fire because "it works just fine"
hahaha. your hilarious man. but yea i care more about my car all together then have a "little" more power until i get a real alt. plus if you have alot of batteries it stresses the alt even more i see flames in the future :ph34r:
Build in Progress
T3 Audio T2000 12
ARC SE4000
DC power 270xp
my youtube channel
Im so glad someone finally gets it. :) Please tell everyone.!!
yes i know it stresses the alt, i dont even have an amp hooked up at this time, just doing it to help top off my batts, should be getting a better alt at the end of march at that time i will be removing this, i was more interested in seeing how it works
\my stock alt is pretty rugged for being stock, so we will see how it fairs
  • Who's Online   0 Members, 0 Anonymous, 1796 Guests (See full list)
