I am going to be running 3 12" and they are rated 1000-2000 watts (and able to handle a 3500 watt burp) but I was looking at the specs and they say "power range: 100-1,000 watts RMS (500 watts RMS per coil)" does that mean if I run 3 like this with a mono block at around 1800 watts I would be over powering them?
On 4/20/2010 at 10:06 PM, 'cc_audio' said:
Guys are just like girls, once you've had 18 inches you don't go back.
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
Sub Amp- (2) PPI 5000BD.1
(2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
(2) 1.5" Bose Tweets
(1) JY 80 AH w/ new JY busses
(1) Duracell 750 up front
Apex Alternators 270
A.C. Delco 160 alternato
if they are rated at 1k each and you're giving them 1800 watts total you will be underpowering them
but they are 500 per vc what should I be running then for 3?
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
500 x (6 vc) = 3k RMS. Your are fine with 1800
Edit: I should have said you are not overpowering them with 1800, sorry.
Edited by shkibbybop
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
to accurately power you need 3k rms total
so look for an amp around 34-3500 rms at 1 ohm just to be safe
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
damn i am confused I was thinking if I was using a mono block amp each positive would be receiving the same power coming off of the amp (like 1800w)
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
right, 1800 watts comes out the positive terminal. it then trickles through the subs in equal proportion because of equal resistance, so each sub gets 600 watts of the original 1800 (1800/3=600), and then each coil sees half of that because again of equal resistance, so each coil is getting 300w
cmon man, this is like gradeschool science
Team DC
k i get it now and thanks for making me feel like an idiot (although i may be one) for asking i guess what is a dumb question :blush:
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
for all we know, i'm the idiot for paying more attention to science classes than sports or beer :/
but for real, www.bcae1.com will answer almost any car audio question you have, so check that out sometime. has a lot of the science related stuff broken down and applied to car audio.
Team DC
  • Who's Online   0 Members, 0 Anonymous, 2871 Guests (See full list)
