parkero801 Posted March 3, 2010 Report Posted March 3, 2010 Just Doin the big 3 upgrade with everything stock i have a lower rpm now when im at idle and while driving i say i went from 800-900 idle to 500-600. why is that?? do I need to upgrade anything else.
Toady Posted March 3, 2010 Report Posted March 3, 2010 Just Doin the big 3 upgrade with everything stock i have a lower rpm now when im at idle and while driving i say i went from 800-900 idle to 500-600. why is that?? do I need to upgrade anything else. Did you check for secure connections with big 3 wires?, If you took the belt off did you check for slippage or maybe not a good amount of bare metal for ground points
parkero801 Posted March 4, 2010 Author Report Posted March 4, 2010 Did you check for secure connections with big 3 wires?, If you took the belt off did you check for slippage or maybe not a good amount of bare metal for ground points yeah I Re-did the whole thing i checked the wires and connectors they were good and solid I sanded off some rust and the paint down to the metal. and connected everything back im still getting a low rpm..seems like its starving for more power..should i upgrade alternator?
Guest Scylloga Posted March 4, 2010 Report Posted March 4, 2010 Ive thought about this for a bit now. The only thing I can come up with is since you did the big three your alt is not having to strain to charge your shit there fore lowering the load on the engine. Kinda like how when you turn the ac on it puts a load on the motor. Maybe your alt was hitting a bottleneck and it was showing it needed to work harder to get voltage and amps out. Now with bigger wire allowing more voltage to flow its not causing a load on the alt.
Gingeriffik Posted March 4, 2010 Report Posted March 4, 2010 ^^^^^^^Beat me too it!!!!LOL Is it possible that with the new wiring that the load demand at idle has been improved, thus a lower idle. I don't think a 500 idle is bad. That is what my hoe does, 5-800. <>< Collosians 2:13-14, Philippians 4:13, 1 John 4:7-10 2 - JBL W15Gti 2 - JBL BP1200.1 Knu 1/0 Wiring Kenwood KIV-BT901 Kenwood/Garmin Nav.
Gutta Trash Posted March 4, 2010 Report Posted March 4, 2010 LOL if you two are right then thats a good kind of scare to have! On 4/20/2010 at 10:06 PM, 'cc_audio' said: Guys are just like girls, once you've had 18 inches you don't go back. 2004 GMC Yukon XL Pioneer AVH-X4700BS 13 band EQ Sub Amp- (2) PPI 5000BD.1 (2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz (4) 6.5 Bose Mids (2) 1" Bose Tweets (2) 1.5" Bose Tweets (1) JY 80 AH w/ new JY busses (1) Duracell 750 up front Apex Alternators 270 A.C. Delco 160 alternato
Baydestrian Posted March 5, 2010 Report Posted March 5, 2010 5-600 idle should be normal...although it could depend on the car...mine idles at 650...when I first start my car its at 1k then slowly goes down 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
cqtama Posted March 5, 2010 Report Posted March 5, 2010 this ^ my car idles at 550 once its warmed up. but as scyloga said you could be putting a bit less straign on your charging system if you noticed a drop. its nothing to worry about R.I.P '01 blazer you treated my ears well until your transmission blew up. New Project [top secret] 149.0 db on music driver window open; so close I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean.... I swear... sometimes I wish I was retarded so I could just agree with everyone x.
