Try gently pushing down on the subs cone and listen for a scrapping sound... While its not powered.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
You said your other sub sounds fine. Disconnect the speaker wires from the good sub and try hooking them up to the problem sub. IF it sounds like shit still, that rules out your amp. IF it sounds good, then the problem is the other channel on your amp.
97 Maxima SE
Bunch of shit going in, check out the build
its a monoblock, i tryed good wire, im on my laptop right next the the sub, i can slightly see the voice coil it doesnt even look burnt.
2 JL W7's @ 1.5ohms - SOLD
Soundstream PCX2000D - SOLD
Yellow top Optima - SOLD
Stock Alt
148db @ 36hz
Distortion doesn't mean a bad coil.... Also the likelyhood of blowing a voicecoil and it still reading 2.8ohm it highly unlikely.
Sounds like your amp or wiring is to blame.
My YouTube Videos
they,re in 2 seperate boxes @ 32hz i actually have the box right to me, do you think it could be blown even if it reads 2.9 - 3.0ohms?
Stock Alt
148db @ 36hz
For shits and giggles, put the reconed sub in the box that has the good sub and try it out just to see if it could be something with the box its in or the wires run in that box.
97 Maxima SE
  • Who's Online   1 Member, 0 Anonymous, 1612 Guests (See full list)
