you can't hook a single 3ohm coiled sub up as 1.5ohm.... sounds like your running an all pass filter on it...
edit: It could have coil rub or have a shifted magnet from shipping.
You can run these subs at 1.5 ohm if they are ran in parallel.
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
Yeah no kidding what are you gonna run them in series out of phase? He didn't mention that he had two.... he Said I hooked "IT" up at 1.5ohm.. not "IT" and my other w7.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
Basically you have to contact JL noone can really help you any farther here... and complaining isn't going to help your situation.
My YouTube Videos
what exactlly is a shifted magnet because when i was looking thru the crack at my coil, and pushing it up and down it coil kinda gets "crooked" as im turnin the subwoofer and looking through each slit where the basket meets the magnet i can see the coil its deff not burnt its really brown with my flashlight
2 JL W7's @ 1.5ohms - SOLD
Soundstream PCX2000D - SOLD
Yellow top Optima - SOLD
Stock Alt
148db @ 36hz
have the subwoofer here as im reading with the multi meter it reads 2.9 and 3.0ohms but when i push the cone down it reads crazy like all kinds of numbers is it because im pushing it down
Stock Alt
148db @ 36hz
I do believe that your impedance will change as the coil moves through the motor. You can verify that by doing it on your other sub.
97 Maxima SE
Bunch of shit going in, check out the build
Yes.
My YouTube Videos
The sub could be "Broken" and not be blown. If you didn't smell any smoke, you probably didn't burn up the coil. Like its already been said, it could be a number of things such as a poor recone job (coil out of alignment), damage from shipping (shifted magnet) or maybe even debris in the gap. Just because the coil reads ok, doesn't mean there is not other problems with it. But we cannot effectively diagnose it here. It needs to be looked at unfortunately.
97 Maxima SE
  • Who's Online   1 Member, 0 Anonymous, 600 Guests (See full list)
