I got offered a straight up trade and everything seems pretty cool to me based on the few things I have heard so far but I wanted to get some more opinions.
Trade includes from me , my 2 audioque 1200's both in original boxes each with its own bass knob.
trade to me would be a stetsom 2k6d. I am looking to give my type rs more power and I want to run the amp at .5 daily will that be safe and what type of power will it put out at .5 or at 2 ohms. what do you guys think about that trade seem like a good deal or what? I was told it should do close to 4000rms at .5 ohms
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
* Previous
o
V 2K6D
* Next
extent photo
V 2K6D
Tecnical Especification
Channels 1
Input Tension 9 to 16V
RMS Power @ 12.6V
MONO 2 Ohms 1 x 2600W
MONO 4 Ohms 1 x 2200W
MONO 8 Ohms 1 x 1200W
Power Consumption 3,3 a 240 A
Frequency Response (FULL RANGE) 20 Hz a 15 KHz (-3dB)
Signal to Noise > 90 dB
Minimal Input Impedance 0,2V
Total Harmonic Distortion < 0,9% THD
Crossover Frequency LOW PASS 50 a 15KHz
Dimensions 70 x 280 x 330 mm
Weight 5,5 Kg
taken from
http://www.stetsom.com.br/eng/DetalhesProduto.aspx?c=169&cat=172
Edited by Army_guy614
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
i thought the stetsom make full power at 2 ohms
least the one i had did
i never ran a stetsom at .5
06' 350Z
Alpine 9886
Sundown SAZ 3500
Sundown SAX 125.2
Digital Design 9515G
Batteries Stinger
CDT ES GOLD X 2
0 AWG Stinger Multiple
alright Ill have to research it a little more but someone pmed me from team stetsom and said his friend ran one at .5 I wanted to double check, so I dont know what to think now
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
i gave you the info you requested, if you run it at .5 ohm have the power to back it up i suggest..
Team DC Audio
I know I appreciate the info though. But theres nothing posted about any tested power at .5 ohms or anyone clamping one at .5 ohms. I also don't know for sure if its safe to run at .5 ohms for a daily setup
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
well the 2k5d would do
MODELS: 2K5D – 2 Ohms
Channels: 1
RMS Power @ 13.8V Mono 2 Ohms: 3300 Watts RMS
RMS Power @ 13.8V Mono 4 Ohms: 2200 Watts RMS
RMS Power @ 12.6V Mono 2 Ohms: 2500 Watts RMS
RMS Power @ 12.6V Mono 4 Ohms: 1850 Watts RMS
Minimum Work Impedance: 2 Ohm
Minimum Input Sensitivity: 0,2V
Total Harmonic Distortion: < 0,9 % THD
Signal to Noise: > 90 dB
Crossover Frequency LOW PASS: 50 a 15 KHz
Freq. Response (-3dB) @ 8 Ohms: 20 Hz a 15 KHz:
Power Tension: 9 a 15V
Consumption with Signal Musical: 2,5 a 140 A
Consumption with Signal BASS: 2,5 a 275 A
Dimensions - mm (H x W x L): 70 x 280 x 1
Weight: 2,2 Kg.
so, i can see the 2k6d doing over 4k rms if its anything like its older brother
Team DC Audio
Don't run it at 0.5 ohms. They don't use a large number of output parts, chances are they're already pushing the package limit at 1 ohm.
Brutal amps though. Lots of power.
10.x volts fo' life!
So will it push more power than 2 aq 1200s strapped at 2 ohms? It definatley would at .5 but if I can't run it at .5 then should I even consider this trade?
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
