if i strapped them then they would get too hot. i would need to link them not strap them is that possible?
if you are thinking this and listenign to shops that woofer is toast within a week
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
you dont want the hifonics... better can be had for the price... i just gave you 2 of your best answers that you will get...
strap(link,stack,daisychain)2 AQ2200d's or 2 SAZ2000's(SAZ1500d's my be easier to find)...
if you have the electrical to back it up...which if you dont you should NOT attempt that much power.... the Sundown amps are your best bet... they do their rated power at 12.8volts... any voltage higher than that will just be more wattage to your woofers... the SAZ1500d's should be able to put out or atleast near 2000rms each if you have the electrical...
and honestly you dont have to strap them... you could most likely get away with running an amp to each voice coil @1ohm... either way.. my statement on amplifier selection stands
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
how much would a sundown 3000 put out at .5 and how much should i put to the woofer
the aq 2200s only put out 1300 at 2
if you strapped two at 2 ohms you are looking at 4500 or so. Again you are not ready for this much power or strapping amps.
I smell smoke.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
you have D1. you run one amp to each coil. that puts each amp at 1 Ohm. giving you ~4500watts.
And whats your electrical like?
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
if you are strapping 2 amplifiers together, you can only run it at 2ohms...
this is my final post in this thread... my final judgement is 2 Sundown Audio SAZ1500d's strapped together and ran @ 2ohms...
or you could just go cheaper and get a single Audiopipe AP3000d and run it at 2ohms... i figure either way you will end up toasting whatever amp you get... might as well toast a cheaper one...
3 Kinetik Hc2000's
Dual 200amp alts.
there's an autotek from sundownz in the "fs" section
1998 Nissan 200sx
NOW:
Dex-p98r head
Planet Audio 300.4 mids and highs
Planet Audio/Pioneer tweeters/crossovers
Skar SK1500.1
3 SKAR Vvx15 dual 4 wired at .63
