well i started the install for my clarion EQ today, all went smooth until i went to test it.. it sounds like SHIT.. no because its not tuned but it sound super staticy, yes everything his hooked up properly
the fronts sound like abosolute shit, i have it wired correctly i have the MAIN IN on the EQ out to the RCA FRONT on HU then FRONT OUT SUB OUT REAR OUT on the EQ going to the desired amplifiers its all correct
now it ONLY sounds like shit with the rcas plugged into the EQ from the HU on the MAIN IN.. HOWEVER if i touch the outside shell of the EQ with the rca prong coming from the HU it all sounds fine, but once i actually plug it in, it sounds like shit
i have tried grounding the rcas... didnt work i tried grounding just the eq didnt work, then JUST the HU.. didnt work and then both and it didnt work
what could the problem be?
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
gonna post a vid in a few
Team Sundown Audio
http://www.youtube.com/watch?v=IjYqZf7S5ZQ
theres the vid
Edited by BeAlLsTaR13
Team Sundown Audio
have you tried switching the rcas around to where they plug into the EQ? May have a bad section on your EQ. it was pretty blurry so it was hard to see.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
yes, as well as on the HU
it works if the positives touch the outter shell on the EQ RCA inputs but once i plug them in i get nothing
Team Sundown Audio
i was having some problems with that thing i got the same 1 i think u can look in my build. i got another 1 and it was fine. also i think theres probably a grounding issue with it somewhere my first 1 did the same thing unless i grounded the rca to the hu but when i got the new i didnt have to also check where the fuse is on that because if it doesnt stay tight you will get static the plastic that hold the 2 white pieces of the fuse holder together breaks sometimes. good luck i know its frusterating
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
yeah ive tried grounding it to the HU and several other places along with the rcas and nothing, the fuse is fine as far as the casing goes
but umm.. i was testing and pulled the power plugs to the ground power and rem and the EQ was still working? i was still getting the straticy shit, pulled the RCAs and touched to the shell of the RCA preouts and it played (like in vif above) wtf?
Team Sundown Audio
heres the first vid i took, took longer to process
http://www.youtube.com/watch?v=nm22BGh3p-8
Team Sundown Audio
  • Who's Online   0 Members, 0 Anonymous, 1261 Guests (See full list)
