ARMYSGT_D Posted March 7, 2010 Report Posted March 7, 2010 it will still play because u have contact through the rca inside the eq but u will not be able to eq it it sounds like u might just have a bad set of rca's i messed with mine for 2 weeks before i figured it out Quote current set-up kenwood ddx 712 clarion eq focal 165 k2p front focal 165v2 rear 2 re audio sexxx 12 us amps md3d us amps md42 1 optima yellow top (rear) 1 xs power 5100r (front) big 3 and 1 run 1/0 stinger wire my build my rebuild
k3n12ock Posted March 7, 2010 Report Posted March 7, 2010 Sounds horrible dude. Quote 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
BeAlLsTaR13 Posted March 7, 2010 Author Report Posted March 7, 2010 ima just send it back for a return if the seller allows it and have him send me another i got this one: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=370334673059&ssPageName=ADME:X:RTQ:MOTORS:1123 he should accept the return cause if im stuck with this POS i file PP claim Quote Team Sundown Audio**CURRENT** -- 2012 Scion tC Build Click Here **OLD** -- 2002 Pontiac Grand AM Build Click Herecheck them out, slap me a comment2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.-------------------------------------------------------------------Head Unit - Alpine CDA-9887Subs - 2x Z 12 v.2s - v.3 + NS Soft partsAmplifier - Sundown Audio SAZ-3500DEnclosure - 3.33 Cubes tuned to 34.66hzFront Stage - JBL P660c 6.5" ComponentsRear Deck - Powerbass 4xl 6.5" Mid-RangeFront Stage Amplifier - Sundown Audio SAX-100.4DWires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAsElectrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700Videos - http://www.youtube.com/user/BeAILsTaR13-------------------------------------------------------------------
ARMYSGT_D Posted March 7, 2010 Report Posted March 7, 2010 same 1 i got my problems cleared up when i got a new 1 hope it works for ui would try the new rca's first Quote current set-up kenwood ddx 712 clarion eq focal 165 k2p front focal 165v2 rear 2 re audio sexxx 12 us amps md3d us amps md42 1 optima yellow top (rear) 1 xs power 5100r (front) big 3 and 1 run 1/0 stinger wire my build my rebuild
BeAlLsTaR13 Posted March 7, 2010 Author Report Posted March 7, 2010 ya ima just get it sent back and for some reason now my lights arent automatic Quote Team Sundown Audio**CURRENT** -- 2012 Scion tC Build Click Here **OLD** -- 2002 Pontiac Grand AM Build Click Herecheck them out, slap me a comment2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.-------------------------------------------------------------------Head Unit - Alpine CDA-9887Subs - 2x Z 12 v.2s - v.3 + NS Soft partsAmplifier - Sundown Audio SAZ-3500DEnclosure - 3.33 Cubes tuned to 34.66hzFront Stage - JBL P660c 6.5" ComponentsRear Deck - Powerbass 4xl 6.5" Mid-RangeFront Stage Amplifier - Sundown Audio SAX-100.4DWires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAsElectrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700Videos - http://www.youtube.com/user/BeAILsTaR13-------------------------------------------------------------------
MrSkippyJ Posted March 8, 2010 Report Posted March 8, 2010 There is a grounding issue somewhere for sure. It could be internally in the EQ or RCAs (or a thousand different ways). Bypass the EQ and make sure it isn't your HU or RCAs. Once you know they work, then you can figure out how the EQ is causing a grounding issue. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
BeAlLsTaR13 Posted March 8, 2010 Author Report Posted March 8, 2010 There is a grounding issue somewhere for sure. It could be internally in the EQ or RCAs (or a thousand different ways). Bypass the EQ and make sure it isn't your HU or RCAs. Once you know they work, then you can figure out how the EQ is causing a grounding issue. the HU works fine and its not the rcas.. i took some from my theatre set up to try and they still did it so its the EQ Quote Team Sundown Audio**CURRENT** -- 2012 Scion tC Build Click Here **OLD** -- 2002 Pontiac Grand AM Build Click Herecheck them out, slap me a comment2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.-------------------------------------------------------------------Head Unit - Alpine CDA-9887Subs - 2x Z 12 v.2s - v.3 + NS Soft partsAmplifier - Sundown Audio SAZ-3500DEnclosure - 3.33 Cubes tuned to 34.66hzFront Stage - JBL P660c 6.5" ComponentsRear Deck - Powerbass 4xl 6.5" Mid-RangeFront Stage Amplifier - Sundown Audio SAX-100.4DWires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAsElectrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700Videos - http://www.youtube.com/user/BeAILsTaR13-------------------------------------------------------------------
MrSkippyJ Posted March 8, 2010 Report Posted March 8, 2010 the HU works fine and its not the rcas.. i took some from my theatre set up to try and they still did it so its the EQ Now you just have to figure out if the EQ is bad or the ground is bad. Are the EQ and HU grounded to the same spot? Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
BeAlLsTaR13 Posted March 8, 2010 Author Report Posted March 8, 2010 Now you just have to figure out if the EQ is bad or the ground is bad. Are the EQ and HU grounded to the same spot? yes, and i even switched them and tried tons of different places.. at least a dozen Quote Team Sundown Audio**CURRENT** -- 2012 Scion tC Build Click Here **OLD** -- 2002 Pontiac Grand AM Build Click Herecheck them out, slap me a comment2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.-------------------------------------------------------------------Head Unit - Alpine CDA-9887Subs - 2x Z 12 v.2s - v.3 + NS Soft partsAmplifier - Sundown Audio SAZ-3500DEnclosure - 3.33 Cubes tuned to 34.66hzFront Stage - JBL P660c 6.5" ComponentsRear Deck - Powerbass 4xl 6.5" Mid-RangeFront Stage Amplifier - Sundown Audio SAX-100.4DWires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAsElectrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700Videos - http://www.youtube.com/user/BeAILsTaR13-------------------------------------------------------------------
MrSkippyJ Posted March 8, 2010 Report Posted March 8, 2010 yes, and i even switched them and tried tons of different places.. at least a dozen Then I would say bad EQ, even if you have already come to that conclusion! Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
