Check out this wiring diagram, I believe all the info is on the picture itself. Please help me out if there are errors, I'm just trying to figure this out. Thanks :D
My First Set-Up (2008)
-Kicker CVR 2 ohm 12's in crap Prefab box
-Rockford digital 1 farad capacitor
-Hifonics Bxi1608d
-DB Link 2 gauge wiring kit
-Pioneer DEH-P3000IB Head Unit
My New Set-Up (2010)
-4 Alpine Type E 10's
-2 Apline MRP-M450's
-Custom box tuned @ 36 hertz
-JVC KD-R310 Head Unit
-Rockford Fosgate 4 Gauge wiring
-Monster Cable RCA's
On the poor mans budget
Do the amps have rca pass thrus? Are you spliting the rca at the headunit or near the amps. You only need two rca y adaptors instead of the four you have in the digram since you only have two amps.
Edited by 8v fury
Pushing it to the limits. Want more power.
looks ok.
On the main power wire i would run two different fuses, one close to the back batt and one close to the front. you can use the second batt as a distro, but i would rec a small fused ditro block. you can find them online on the forums for about $15.
The deck may end up causing issues, in theory you can use the splitters, i'm just worried the voltage is already so low, that after the splitters your amps will be recieving very little voltage from the radio.
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
I'm splitting at the head unit. I have 3 y-adaptors because that way it will make 4 jack for rcas for each amp.
like this kinda...
Y Y
Y
looks ok.
Do i run the ditrso block right after the second bat? And is there any other way to fix my rca problem?
-Hifonics Bxi1608d
yeah, run the distro right after the second batt. not required, but the fused ones add a little piece of mind to your setup. The only way i know to fix the RCA issue is
1)attach a pair of LOC's to your speaker leads
2)buy a line driver
or the best option
3)eventually get a different deck. but i'm sure you already knew that
EDIT:
http://www.caraudioclassifieds.org/forum/showthread.php?t=32872
use this and then daisy chain the amps like crump have said. so the sequence being
1rca out>splitter>line driver(or not)>inputs of first amp>out of first amp to inputs second amp
Edited by hotshot27
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
Why cant you just run one y splitter to one amp, then run a set of rcas from that amp to the other? and you can ground the amps at the battery if you want, but the chassis works fine also. Then you gotta fuse the amps within 18" of the battery or closer. Also with your remote turn on wire you can just run one to one amp, then daisy chain it to the other like the RCAs. Pm me if you have any other ?'s
2)buy a line driver
or the best option
EDIT:
Problem is, there is only input on the amps no output
-Hifonics Bxi1608d
then i would go back ot your original drawing, but insert the line driver after the first y-splitter
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
alright..is a line driver a rockford 3 sixty?
-Hifonics Bxi1608d
If i couldn't get a line driver right away then how much power would i be loosing from my 3 y-splitters, rcas, then to the amp? would it be significant?
-Hifonics Bxi1608d
  • Who's Online   0 Members, 0 Anonymous, 695 Guests (See full list)
