please suggest me whether is it ok to use amp t1001bd for two subs t1 15"?
but my amp is 2 channel....not one channel...can i modified the wiring like u suggest for my amp?
Bridge your amp and vola! you have a one channel amp.
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
The T10001bd amp is a mono amp... You see 4 speaker outputs on the amp but that is only for convenience.
You want maximum pressure, for sure ! (like SPL : Sound Pressure Level)
But maximum vibrate ???!!! No !!!
Maybe you can show the OP how to use all 4 speaker outputs on his amp to achieve a 1 ohm load with his 2 subs?
I don't know where to find that diagram.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a 2.6 ft3  ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Wire each sub parallel and hook one sub to one set of outputs, second sub to the other set of outputs
you cant bridge it, its only one channel, hence the extra "1" in the model name
there is one + and one - that happens to have two spaces to connect wires. just like youre one person with 2 arms, that amp has one terminal with 2 holes and screws.
follow that diagram and stop thinking so damn much.
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
