It'll power them but I don't think that it will be all the power those subs can take. They'll be under powered.
Edit: nice deal by the way
Edited by blackrosetiger
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
2 BTLs.. get dual 1 ohm.. series the coils, then parallel the leads to the speakers. that way your amp will see a 1 ohm load.
don't forget to break them in a lil... and use 8 gauge for speaker leads. It's worth it
what electrical setup?
alright thanks. and 1/0 gauge wire and a kinetik battery in the back. im sure ill need to get a h/o alternator.
should sound pretty nice when you get a bigger amp down the road should sound even better
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
Just build the enclosure accordingly to maximize the BTLs output.. Basically build an enclosure on the larger side of the recommended specs, so that the subs will handle the power more efficiently. Also make sure that you have the proper electrical upgrades for that amp.
Pioneer AVIC-N2
  • Who's Online   0 Members, 0 Anonymous, 965 Guests (See full list)
