TyC2010 Posted March 10, 2010 Report Share Posted March 10, 2010 I am going to have 2 Fi BTL 18's. will a rockford fosgate T30001BD power it ok??? I found a refurbished one for around $500. Quote Link to comment Share on other sites More sharing options...
Watch the bass Posted March 10, 2010 Report Share Posted March 10, 2010 I am going to have 2 Fi BTL 18's. will a rockford fosgate T30001BD power it ok??? I found a refurbished one for around $500. Sweet Quote "in the abundance of water, the fool is thirsty" Bob Marley Link to comment Share on other sites More sharing options...
blackrosetiger Posted March 10, 2010 Report Share Posted March 10, 2010 (edited) It'll power them but I don't think that it will be all the power those subs can take. They'll be under powered. Edit: nice deal by the way Edited March 10, 2010 by blackrosetiger Quote 1998 Plymouth Voyager (daily) Jensen VM9213 H.U. (I Know but I havent had any problems.... yet) 5.25" Factory -> Sound Stream SST5.2 6x9 Hifonics ZXi 693 -> Sound Stream SST6.9 Amp: Class D: Crescendo 3KWP (x2) Class A/B: Crescendo 1000C4 Sub: Almani S-7 10" (x6) Link to comment Share on other sites More sharing options...
kmalinich Posted March 10, 2010 Report Share Posted March 10, 2010 2 BTLs.. get dual 1 ohm.. series the coils, then parallel the leads to the speakers. that way your amp will see a 1 ohm load. don't forget to break them in a lil... and use 8 gauge for speaker leads. It's worth it what electrical setup? Quote Link to comment Share on other sites More sharing options...
TyC2010 Posted March 10, 2010 Author Report Share Posted March 10, 2010 2 BTLs.. get dual 1 ohm.. series the coils, then parallel the leads to the speakers. that way your amp will see a 1 ohm load. don't forget to break them in a lil... and use 8 gauge for speaker leads. It's worth it what electrical setup? alright thanks. and 1/0 gauge wire and a kinetik battery in the back. im sure ill need to get a h/o alternator. Quote Link to comment Share on other sites More sharing options...
kmalinich Posted March 10, 2010 Report Share Posted March 10, 2010 oh yeah. you should get a DC power alt... look for Kyle on here... he'll hook you up.. Quote Link to comment Share on other sites More sharing options...
TyC2010 Posted March 10, 2010 Author Report Share Posted March 10, 2010 Alright thanks man Quote Link to comment Share on other sites More sharing options...
ARMYSGT_D Posted March 10, 2010 Report Share Posted March 10, 2010 should sound pretty nice when you get a bigger amp down the road should sound even better Quote current set-up kenwood ddx 712 clarion eq focal 165 k2p front focal 165v2 rear 2 re audio sexxx 12 us amps md3d us amps md42 1 optima yellow top (rear) 1 xs power 5100r (front) big 3 and 1 run 1/0 stinger wire my build my rebuild Link to comment Share on other sites More sharing options...
Marlo Stanfield Posted March 11, 2010 Report Share Posted March 11, 2010 Just build the enclosure accordingly to maximize the BTLs output.. Basically build an enclosure on the larger side of the recommended specs, so that the subs will handle the power more efficiently. Also make sure that you have the proper electrical upgrades for that amp. Quote 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
loganberry Posted March 11, 2010 Report Share Posted March 11, 2010 yea it will work, figure you would get about 1750 watts to each that should be good...just make sure you have good voltage, ive seen lots of fosgate amps burn up from having low voltage Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
