LiL PiNoY Posted March 13, 2010 Report Posted March 13, 2010 Having problems with my voltage dropping from about 13.8-14.1 to 13 when warm at idle when i have my headlights on and the air off. Then I accelerate and it goes back to normal until I stop at a light again. With headlights on and air on its fine. also it doesn't happen when I am parked and the car is still on. Replaced the front battery with and acid because of the cold weather used to have a kinetik 2000 up front and kept the kinetik 2400 in the back. Big 3 is done and I have an HO ohio alternator. Could this problem be the battery dying because I beat on it to hard or is the alternator failing?
hotshot27 Posted March 13, 2010 Report Posted March 13, 2010 watch you RPMS. in my car, at 750rpms' i'm lucky to get 12.5v but at around 850rpm's im sitting at a solid 14. some cars/alternators need to idle a little higher to put out power.(when im in drive i idle about 100rpms less than when in park.) Current Setup: Factory HU with LOC mids/highs-Insignia components Sub- E8 in bass tube Amp- sae-1200d Show Setup: HU-Sony MEX-1HD (brings massive respect for sony) fronts - Infinity Kappa perfect comps rears- Infinity Kappa coax mid/high amp - Autotek 5600 Subs - 2 RE SE 15's Sub Amps - 2xSAE-1200D Box - 5cubes sealed Wire- Lots of Knu 1/0 SECOND SKIN
kmalinich Posted March 17, 2010 Report Posted March 17, 2010 yeah, the alternator just can't produce enough amps at idle. it's just physics
LiL PiNoY Posted March 19, 2010 Author Report Posted March 19, 2010 Well I usually idle at 600rpm and when the lights are off it sits at 14 but when they are on it will go to 13 if I have the air on I idle at 700rpm and then it will sit at 14 does that mean the alternator produces next to nothing when there is a load on the alternator because its supposed to idle at 105 amps
Gotloud555 Posted March 21, 2010 Report Posted March 21, 2010 Could be that alternator you have doesn't put out that power you looking for. You should got find a shop that bench tests that alternator, and see if doing what it really say..
