Once again, thanks for all the compliments on the build. I got some more photos for you guys.
While the glue on the baffles dried, I built the first of three panel braces. The braces are all going to be 1/18" MDF.
Test fit the of the first brace.
Check out my caraudio builds.
http://www.stevemeadedesigns.com/board/topic/72104-scary-truck-rebuild/
Check out our Custom Home Theater builds @
www.SoundAdviceUtah.com
R.I.P!
(Nov-29-2009)
92 explorer
current build
Looking sexy. This is going to be sick what was the tuning of it again?
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
34hz Is what I came up with on my Term labs software. It shows a 9.9db bump at 40.4hz and a free field 3db down of 25hz. Enclosure volume is 20ft. I can't wait to find out what it will do in the truck. My goal is to get some serious output below 20hz. That should be no problem.
