So currently i have 2 type-r alpines in a box, and i was wondering what amp or what level of amp i should push them with, i dont know anything else about the subs. also anybody who might know anything about the subs them selves would be helpful.
What ohm are they, I.E. Dual 2/4, Single 4 etc..... also what is your price range, you want around 1000-1200rms for a pair of em. Now the amp depends on what coils they have, and how much you want to spend.
¿ǝɯɐƃ ǝɥʇ
Thats part of the problem, i dont know. all i know is that theyre 10" alpine type r's. i dunno if they make several models of this or anything, im not in the least knowledgable about audio systems or electronically speaking forums. thats why i posted this. i need info about the subs and i need info about a compadible amp that will hit them hard but not destroy them, i havent even run the wires for my car yet. i have 94 grand am se, and i accidentally set off the delco II anti theft alarm. i actually took out the radio without disarming the alarm
Edited by Andyroohoo
are there 1 or 2 terminals on the woofers?
and is there a model number on the magnet or anything?
or maybe an ohm rating?
this will help us with amp suggestions.
I would be safe and start with around 1000 watts, Sundown Audio has a SAZ-1000D that would do a great job with those Alpines
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
well, i can really get to the model number, as the two subs i have are in a box.i have i think a 750 watt amp. im not sure though, so these are the specs, tell me what you think:
MTX Blue Thunder Pro 75x2.
37.5 watts RMS/CH x 2 into 4ohms < 0.05% THD+N
75 Watts RMS/CH x 2 into 2 ohms < 0.1% THD+N
150 Watts RMS bridged into 4 ohms < 0.1% THD+N
375 Watts dynamic power (IHF-202) Bridged into 4 ohms (14.4 VDC)
RMS Power Ratings @ 12.5 VDC, 20Hz-20kHz
i think that's no where near enough power. and you have at most a 150 watt amp. but then again you take into account...efficiency and input voltage and other factors... she's probably putting out about 110-130 watts.
dynamic, peak, music, any watt rating that isn't "RMS" is bullshit. every time
oh.. and the subs are in the box... so you can't get the model..
use your brain. TAKE THEM OUT OF THE BOX. OH MY GOD, REVELATION!!
Edited by kdicetharappa
run 4 gauge wire and get a saz 1000 as suggested itll be clean and loud as a first system... also run rcas on the oppisite side of the power wire and make sure a solid ground and all that. just turn the gain down and be careful with it. if you really want go to a local shop and have the o-scope everything
2004 Grand Prix
HU: Alpine 9886 :( for sale
Sub Amp:AQ2200d (possbly 2)
Enclosure:BCP Designs. Best for the Money
Electrical:1 Stinger SPV70 battery
Subs:2 15 D2 AQ HDC coppers
Wiring:0gauge power SoundQuest
Wiring:0gauge ground Kicker
141.8 @ 28hz tl legal on the dash.
142.6 @ 33hz tl legal on the dash.
SAZ1000 won't do him a lot of good if he has dual 2 ohm subs and has a two ohm final load.
You need to get them out of the box and look at the subs to see what model they are. And if there's no model # you can test the impedence with a digital multimeter.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
exactly. post back if you have questions about using a digital multimeter... we will be happy to assist :D (well at least i will be)
