Can you wire 8 door speakers to a 4 channel? My friend wants to put 4 sets of infinity kappas on 2 ohms in his front doors with the minimal # of amps. he already has a pair of jl w3s that will be going in there but plans on running them on a 2 channel...
yes 2 speakers parallel on each channel
03 Ram 1500 3.7 v6 quad cab
H/U: Pioneer 4200UB
Subs: 4 DC LVL 4 15s D1
Sub Amp: 2 Crescendo 3kwp strapped
Highs Amp: Crossfire xp240.2
Highs: Crossfire 2 rs69, 2 rs52
Alt: DC POWER ALT 270XP
Batts: 5 sprinter data safe
Big 3 0ga
New Truck 03 Ram Build Log 6 DC Audio lvl2 15's
My Wrecked 99 Dodge Ram Sport Build Log
02 Ranger X Cab Build
02 Ranger Build 2
http://www.dcsoundlab.com/
My linkhttp://www.crescendoaudio.com
http://www.dcpowerinc.com/
http://www.crossfirecaraudio.com/
Youtube Vids
ok thought that would work but wasnt sure....if the speakers were 90rms each how large of an amp would he need? 150 a channel? or 100 a channel?
90 RMS 2 speakers a channel, the amp should put out 180 RMS at 2 ohms if your running it at 2 ohms, and MAKE SURE IT'S 2 OHM STABLE! trust me, having to buy a new amp because yours shuts off all the time...
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
do the math man. you have 2 90wrms speakers 2 ohms a piece on one channel. you can wire them to 1 ohm or 4 ohm. if you have an amp that can only do 150 watts at 4 ohms on a single channel then how many watts you think them speakers are gonna see?
Quote
he could wire in series if the amp could handle 2 x 4ohm bridged. i have a two channel that is 400wrms @ 4ohm bridged and i have 4 speakers wired in series and then in parallel to make a 4ohm load.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
I know i sound like a dumbass but Ive had ppl tell me that the speakers will get 150 watts..so each speaker would get somewhere around 75 watts each?
you dont sound like a dumbass itll just help you understand it better if you figure it out pen n paper stlye. but yea your right 75wrms as long as the amp is seeing the resistance its rated for. if you lower the resistance of the circuit the wattage will go up.
Quote
Something such as a good four channel 600-800rms amp will get those infinity speakers to singing nicely.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
